First, I’d like to mention that this bike looks MUCH better than its rim brake counterpart.
Second, it’s not faster:
In terms of aerodynamics, the ViAS Disc gives up a few seconds to the rim version. Chris Yu, Specialized’s head of applied technologies, said that at low wind angles, from +/-5 degrees yaw, the disc bike is 2-4 seconds slower (over that 40km at 40kph) than the rim bike. At greater yaw angles, such as 10-15 degrees, the difference grows to about 10 seconds if the wind is coming from the non-drive side and hitting the rotors. If the wind is coming from the drive side, however, the difference is just 2-4 seconds, Yu said.
One thing I noticed is that they didn’t seem to make much of a change to the front fork. One of the few arguments I’ve seen in favor of disc brakes is that it opens up possibilities with the fork, specifically around the fork crown.
The only argument I can make in favor if disc brake rotors is the ability to build compliance into the frame.
Otherwise, all I really want is through-axles on my tri bike. I know it’s overkill but I just like the idea. I could care less about disc brakes.
I wonder how they are comparing weights i.e. is it frameset, do you include the brakes on the rim model? Then again the fork crown and the seat tube had to be built up a ton to support the spreading forces created by the brakes.
In addition to the 100x12mm front / 142x12mm rear thru-axles and flat-mount adaptations instead of rim-brake caliper mounts, the disc frame has a better weight-to-stiffness ratio, Specialized claims, weighing nearly 200g less than the original frame.
I’m glad to see specialized moving away from their proprietary through axle rear end in both the VIAS and the Crux. Hopefully the redone Roubaix will use the std. rear end spacing as well.
Overall it is a better looking bike, but if I were to win the lottery tomorrow and wanted a fast bike I would still get the rim brake VIAS. Still happy with my Allez Sprint though.
As I noted in the other thread where this bike came up, Specialized deserves extra credit for making an already ugly HB configuration even uglier…
Sorry, I just think the whole idea of this bike is dumb…but I have no doubt that people will buy it. At least people can get a Venge Vias with brakes that work really well, I guess…
If you regularly rub elbows w/ Cavendish or Greipel, no you can not race discs. If you live in the US you can race discs in any event that is US Cycling sanctioned but not the few that are UCI sanctioned. If you race triathlon then race whatever you want, sky is pretty much the limit. It is too complex to figure out in general. If you aren’t paid to ride bikes I wouldn’t worry about it and ride what ever you want. If you are paid to ride bikes then ride what ever your sponsor gives you
the article mentions that specialized engineers think the bike is faster overall because you can brake later into the turns using discs. Man…I don’t know about that. With 140mm rotors, my gravel/cx bike doesn’t brake any better than my rim braked bikes. I’ve also heard of people overheating their 140mm rotors on long technical descents.
I’m going to switch to 160mm rotors for cx season. I suspect there will be even more drag at yaw (probably about the same at 0 degrees) but the extra stopping power in CX far outweighs the drag or weight penalty. On a road bike, maybe not.
I still think road disc is a solution to a problem that doesn’t exist, or at least exists for rare people that live in a very unique area.
+1
and disc brakes are just unsightly.
What bold and original statements that I have never heard on ST before. What you mean is “road discs are a solution to a problem that doesn’t exist for me”. While marketing them on relatively single purpose aero race bikes may indeed be silly, road discs themselves may prove to be a perfectly sensible solution to a problem that is widely faced by seldom acknowledged by elitist snobs; not everyone wants own, store and maintain a stable of single purpose bikes. Discs open up the possibility of having 1 bike with enough clearance to ride on and off road, cross or gravel, commute or race with some compromises.
Of course a jack of all trades bike is going to be inherently worse when compared to the highest possible form of dedicated design in each respective category but despite delusions of grandeur, last time I checked these boards were full of mid-life crisis dads and not professional athletes for whom every second saved could be make or break.
Now is the bike in question a bit silly? Most likely, but honestly it doesn’t matter what bike we’re talking about on these boards, you’ll always have 10 people chime in with the same n=1 comments suggesting that they know what is best for everyone else.
I have 2 thoughts:
1.) They misnamed it…but, I guess they didn’t wan’t to license “Oxymoron” from me
2.) Looks like my custom steel aero bike might give it a run for it’s money…
+1 on the 140mm rotors on road bikes…needs at LEAST 160 on front IMHO.
On a related note, I just did a twisty, 8% average grade descent at lunch on a bike equipped with hydraulic calipers and 622mm braking discs with a specially treated metallic surface.
I guess this isn’t a place to share opinions. Anyway, back to my experiences…
I do ride my Felt F1X disc CX bike on road, gravel (with aero bars), CX courses, and single track. Yes, it is a bike that meets the needs of many different scenarios. If I had to choose one bike to keep, it would be a tough decision between the F1X and my Emonda.
However, I don’t think it is any better because of the disc brakes. As i mentioned, the discs don’t seem to stop me any faster than rim brakes. They aren’t easier to setup. They don’t last longer. I can lock up my rims brakes just fine, and they modulate just as well. Whether I’m on MTB trails, CX courses, road, or gravel I think rim brakes are as good.
As I think about it more, I guess MAYBE you can argue rain riding. I’m not sure, as I haven’t done much riding in the rain on a disc bike. I haven’t really had problems braking in the rain (too much brake is usually the case) but I guess discs might give you instant bite where rim brakes on carbon wheels hesitate for a split second before they bite.
I have 2 thoughts:
**1.) They misnamed it…but, I guess they didn’t wan’t to license “Oxymoron” from me **
It’s not just about consistent braking power in the wet - it’s also about brakes that leave room for big tires and fenders that also don’t grind your rims into oblivion after a few months of wet riding. Here in the PNW my alloy rims with v-brakes and kool stop pads make it 12 months max before being sketchily worn out. I am planning to go ‘separate braking disc’ in the near future for these reasons alone.
Moving the Vias to disc is actually kind of an interesting move - it is impressive that they were able to make the change with so little penalty. It is, I think, a quiet acknowledgement that the trick behind-the-fork and seattube brakes were not consistently performing up to snuff or were too much of a pain to be viable for most customers. The disc model will probably be less of a headache to operate vs the integrated rim brakes.
All that said, yes Tom, you can still build a fast bike with normal brakes that works great and is less of a pain in the ass to work on… people who want that can buy an S5.
