Shallow water blackout should never be an issue in a pool, which is far too shallow. SWBO happens when someone dives to a depth that significantly raises their oxygen partial pressure (PPO2). Due to the higher PPO2, you don’t feel the need to breathe as soon (and hyperventilating enhances this effect), and then as you begin to surface your PPO2 drops rapidly, starving the brain of oxygen and hence the blackout. I really don’t see how you could ever get deep enough in a normal pool for this to be a concern.
-David
I can’t believe I’m defending he hall monitors on this. Your post is so wrong in a couple of ways. If you’re joking then I’m not sophisticated enough to get it.
First, SWBO is just that. Shallow Water Blackout. You don’t even need to be under water at all (it’s just that it’s dangerous when in water). As I have stated in a previous post I have blacked out many times from holding my breath, NEVER IN THE WATER! I’ve done it on my couch. I’ve done it on a spin bike. I’ve done it laying in bed.
Second, partial pressure concentration issues only occur when you are breathing compressed air at depth (scuba diving). These free dive world record guys sometimes use compressed air and run into issues related to that. One of the problems is O2 toxicity. Over a certain depth the concentration of O2 is so great it becomes lethal. Fortunately, this happens at a depth greater than you can use normal compressed air due to the nitrogen problems. But that’s all useless info here.
Bottom line, you can pass (and I have done so) pass out without water and it is certainly possible in a pool.
Again, if you were joking, sorry.
All due respect, Duffy, but you are the one off base. I’m not joking at all, and while I certainly don’t profess to be an expert, I do have some experience with this from years of teaching scuba diving. It all comes down to basic physics and biology. From the physics perspective, look at Doyle’s, Dalton’s and Henry’s laws pertaining to gasses. From the biology perspective, keep in mind that the body, and particularly the brain, relies on the partial pressure of oxygen as opposed to the percentage of the gas for metabolic functions.
Oxygen partial pressure issues are definitely not limited to diving on compressed gases. Sure, it’s true that oxygen deprivation to the brain will cause blackout at any depth or at the surface, but the biggest single cause of shallow water blackout is skin diving and passing out while at depth, typically while rising to the surface. To better understand this, perhaps an example is in order. I’m going to use 33ft/10m (2ATA) as the depth, since it makes the math simple.
At the surface (1ATA), the skin diver takes a breath containing approximately 21% oxygen. According to Dalton’s Law, the PPO2 is (1ATA* 0.21), or 0.21. Since the brain requires a PPO2 of at least 0.16 for consciousness, no problem. Now the skin diver descends to 33ft/10m - the PPO2 is now (2ATA * 0.21) or 0.42. The diver now swims around for a bit, and the oxygen in the body gets metabolized and begin to drop, let’s say to around 0.2, still enough to keep the brain conscious. Now the diver begins to ascend, and as the ambient pressure decreases, the PPO2 drops. Say the diver is now at 16.5ft/5m, the PPO2 would now be (1.5ATA * 0.1) or 0.15. This level is now below the level the brain needs for consciousness, and blackout is a very high likelihood.
Someone pointed out that hyperventilation is the cause of shallow water blackout - this is also not technically correct. It’s true that hyperventilation is often associated with shallow water blackout as by flushing out CO2 from the lungs before descending, the diver’s urge to breathe may be delayed until after the critical point at which the PPO2 drops to a level where blackout can occur. Avoiding excessive hyperventilation is certainly a legitimate way to minimize the risk of blackout, but hyperventialtion is not the root cause.
You correctly point out that you can blackout at the surface without even being near water. This is not shallow water blackout, but simple oxygen deprivation. The PPO2 still applies, it’s just that the ambient pressure never goes past 1ATA. Of course, if you black out and you’re in the water, you run a very high risk of drowning, which is why shallow water blackout is so dangerous. Blacking out by holding your breath on the couch is a pretty silly thing to do, but as soon as you lose consciousness your brain will come to your rescue and restart the breathing process by itself.
Regards,
David
