I am 6’3", 205lbs. I need a good, solid running shoe. This last year, I wore the Saucony 3D Grid Hurricanes and liked them. I am thinking of trying the Asics Gel Kayano X.
We sell a fair number of both shoes each week, so I’m pretty familiar with both.
First: support your local running store and go try both on, and try on the 1122 and also the Brooks Trance if you can find it. All those shoes are in the same category and same price range, yet will feel VASTLY different on your foot.
Second: The different companies use different “model” feet when designing their shoes. Asics is going to fit a narrow, straight foot fairly well where Saucony will fit someone with a wider forefoot and narrower heel fairly well. Some people don’t feel a difference, other people feel a dramatic difference. YMMV, so go try them on.
Third: The Hurricane is generally a more “stable” stability shoe than the Kayano. If you need the extra stability because you overpronate, the Hurricane might be better. On the other hand, the Hurricane is a much “firmer” shoe than the Kayano, which has a lot more heel cushioning. If you tend to land hard on your heels, the Kayano might do a better job absorbing that shock.
Fourth: Working on form is a good thing, because it allows you to build the strength you need to do the work that a stability shoe does for you. The more you can land on your forefoot, with your knee bent to take the impact in your quads, the less need you have for cushioning & stability. This is a whole long thread that will probably elicit a lot of religious postings, but the net is this: if you want to invest the time & energy in improving your running form you can get faster, be more efficient, and run in much lighter shoes. If you don’t want to make that investment, the shoes you described will do a good job preventing overpronation and will help keep you from getting injured.
Lee Silverman
JackRabbit Sports
Park Slope, Brooklyn
