Need help identifying base bar P/N (Specialized Shiv TT)
Good day,
Need help identifying part number for straight pursuit base bar on Shiv TT.
I’ve checked all possible catalogs and still can’t find what P/N this base bar is.
Found a “Bending Grip” one, but it’s a little different.
Attaching image as reference.
Thank you very much.
http://radhaus-ansbach.de/wordpress/wp-content/uploads/2013/05/Bild-2.jpg
Anyone ? :frowning:
Have you tried asking a specialized dealer? You probably have to buy it through them anyway
Yeah, 3 of them, they could only find a bending grip one.
I’m for sure seen 2 different straight grip models (white + red and just white),
so pretty sure there is more than one item available :frowning:
Checked all listing for 2014-2019 models (local dealer showed me listings they have using official spesh dealer site) - no signs of this type base bar.
Look up the originally shiv TT (2011) also some of the 2012 black and white modes (like pictured) were cut short to take out the bend. Easily done!
The bar you are looking for came on the Shiv TT frameset modules from 2013-2016. Some 2017 models also appear to have been shipped with the flat bar but the up-bend bar was phased in and seems have been only option with 2018-2019 modules.
I can find images of pro team bikes still using the flat bar but that they may be coming from a secret stash. My instinct is that Specialised isn’t stocking that bar anymore which is why you can’t find it on a dealer system.
Just talked with local Spesh dealer again, they said its “Team Issue” and they couldn’t even see such items.
Catalogs for other years shows random stuff not related to this base bar.
Official Spesh support email is silent - no response for 2 weeks.
Is there any other major Spesh dealer contacts available? Canada, EU ?
I’m quite sure a bike mechanic of team that uses Shiv(s) as TT bikes knows this P/N, unfortunately I can’t find so far.
What you need is a specialised dealer to work backwards from Part No. 79117-0503 (https://www.specializedconceptstore.co.uk/...orks-shiv-tt-module/)
Its clearly not just a team issue part but it might be that Specialised never assigned a unique Part No to the bars and so you need to work backwards from the module.
Edit: It looks like part Numbers 79117-050X all cover the correct build setup with the final number referring to the paint.
Thank you very much for answer, here is what dealer sees for 2017 yr model (he sent me an PDF)
I think it’s kinda restricted to country of sales (TT modules are not selling here)
2017.pdf
