6 week old !? I have twins on the way and have been looking at what to do about running with them. Everything I have read says not to run with them until at least six months when they can hold their necks are strong enough to keep there heads up.
Anyone else run with kids that young?
Since a baby can’t talk, and there are many types of injuries or potential lifelong problems, that are not outwardly shown by a babies response or lack of a negative response, one might consider erring on being conservative. This is from the baby jogger website. Consider hitting the treadmill, gym, and early or late day run, etc. solo or just go for a walk with your little one in an appropriate stroller. Give the little guy/gal the best chance possible.
Q. How old should my baby be before I can jog or run with them?
A. We recommend that you speak with your pediatrician before starting this activity. Every baby is different, but typically a doctor will recommend that a baby be 6 months old before you jogging on smooth pavement, and 12 months old before jogging on trails, grass, gravel or uneven terrain.
back to top
Bob recommends waiting until 8 months to go jogging.
http://www.bobgear.com/faq2
A jogging stroller can be an active mom’s best friend since it allows you to get out and get moving with your new baby in tow. But like umbrella strollers, jogging strollers aren’t designed with the physical needs of your newborn baby in mind. If you’re planning to use a jogging stroller, make sure you time your use correctly.
The Facts
Some jogging strollers are labeled as safe for babies as young as six to eight weeks, but most babies can’t ride safely in a jogging stroller until they are at least six months old, says “Consumer Reports” magazine. Your baby needs to be able to hold her head up comfortably before she can handle riding in a jogging stroller, a milestone that can vary from baby to baby but usually doesn’t happen before your baby is at least four months old.
Significance
Jogging strollers can cause problems for very young babies because their necks aren’t strong enough to support their heads, leaving them susceptible to potential injury when they’re riding in a bouncy jogging stroller. Even when your baby can hold his head up, it’s wise to make sure that your jogging stroller has good head and neck support, a secure harness system and maximum shock absorption to reduce injury risk.
Considerations
If you run near high-traffic areas or on uneven terrain, you may want to save your jogging stroller until your baby is at least a year old and can wear a helmet while you run, notes “Consumer Reports.” It’s also important to make sure that your baby is the right size and weight for your jogging stroller, notes REI. Running with your baby in a jogging stroller that’s too big or too small for her can cause injury.
Read more: http://www.livestrong.com/...oller/#ixzz27dgOMTsH
