What I’m looking for is an explanation of what muscles are used during each phase of a running stride.
When are hamstrings used? Calves? Glutes?
Other question, what function do the arms play in a running stride?
Also, I know this gets tricky to even ask, but when your foot comes forward after trailing behind, it’s my understanding that before it lands on ground, it already proceeds to move back… is that right? Is this where hamstrings come in? And once the foot lands on firm ground, is where calves come in to play… correct? What muscles are primarily used when the foot comes forward? None? Is it gravity that’s used instead of musculature? Is it hip flexors?
Yes, I’m trying to piece everything together, which means I’ll probably get a bunch of ‘just go out and run’, or ‘run more often’ type answers, but I’m asking more out of a desire to understand the biomechanics of running.
Quadriceps cross two joints, the hip and the knee. They straighten the leg at the knee and also bring the upper leg forward in relation to the torso. Hamstrings do the opposite, they flex at the knee and bring the leg rearwards. The calf muscles extend (point) the foot, and the tibialis anterior is the primary ankle flexor (opposite of toe point).
In a very general sense, the quad raises the knee up, then extends the lower leg out in front of you. The tibialis flexes the ankle so your toes raise. As you land the foot, gravity and the hamstrings are taking over. The hamstrings move the lower leg back (or the torso forward depending on your point of view) as you pass over the foot. They then raise the foot off the ground and start bending the knee more as the calf muscles point/push off. Glutes are activated in concordance with the hamstrings.
Lather rinse repeat.
The arms stabilize and balance, and the magnitude of the swing enables greater strides. You can run faster without increasing arm motion, but it becomes more and more awkward.
Caveat: This is extremely simplistic.
John
