Wow, I finally got a chance to peek into this site, and I’m highly impressed. Not only because this is the way I coach, but how extensive this site is, even for advanced swimmers. It really solidifies what I have been hammering into the poor souls of the technique lane at the TCSD swims.
Some of my favorite parts:
Kick - “I’m a triathlete, I don’t have to kick” - Love this one.
6 beat kick, opposite leg kicking down, when arm enters, then same leg kicks when arm is in the middle of the catch (pull). Seriously, click this link. http://www.swimsmooth.com/kick_adv.html
Two most common mistakes I see in the kick, are knee bend and flexing the foot. Correct it: Kick from the hip, and let the pressure of the water point your toe. If you put too much effort into pointing your feet, not only will they get a cramp, it probably means you are too tight. Which then leads to body position errors (tight legs sink you). “Triathletes, you’re not looking for propulsion!”
Forces/Pressure - Simple: If you want to move forward, you have to push the water back. Not sideways, not hour glass, no S curves. Back. Changing the angle of the wrist and forearm to keep that elbow “high” will keep the water moving back. (I hate the term “high elbow” because most people don’t understand it - elbow points towards the side of the pool, rather than the bottom.) This starts from a proper shoulder width entry, not hitting/crossing that center line.
This site is super helpful for me as a coach. I’m always thinking about different verbiage when an athlete of mine isn’t “getting it.” Sometimes all it takes is explaining it in a different way.
Ah, the swim pyramid. This is how I structure my technique sessions. Only having an hour, I can’t get to everything, but generally I start with body position (kicking drills) then move to rotation drills (ah, the dreaded no arm roll/core drill, you know you love it!) and end with one of the level 3-4 items (front quadrant swimming…been using that since 8th grade swim camp!, catch setup, or entry) Start from the back and move forward.
http://www.swimsmooth.com/hierarchy.html
Now, with all that said, the internet cannot be your only swim tool. How do you know if you putting pressure in the wrong direction? How do you know if you are “dropping your elbow”? How do you know if your timing is off?
Hire a coach.
One who will get in the water with you.
