Does anyone have an XLab Super Wing and Mini Bag? I can’t for the life of me make any sense of all the velcro straps. Can someone help me out here, or even post pictures of your setup? Thanks.
Jason
Jason
That’s because the straps on the bag make no sense with the superwing. You use them if using the mini bag by itself under the saddle for short rides. On the big wing you need the xlab straps (one on top for the little guy and one below for the big bag or kona bag). You can jury-rig something with some velcro or rubber bands, but really just get the stupid straps.
Thanks, that helps. Now I know I’m not crazy not being able to figure out the straps on the bag.
I’ve got the short top strap from the wing itself mounted but I still can’t figure out how it’s supposed to hold the bag in place. I don’t have a bottom bag or Kona bag, is that my problem? Do I need a lower bag mounted to hold the mini bag up?
Jason
I just put it in the top, tip down-ish and it buts against the cross bar so it can’t go down. Then the strap across the top to stop it bouncing out on a big bump.
