Mount tablet for Trainerroad with clip-ons?
Hi All,
I’m about to get my Trainerroad on after a winter run focus but as I was setting everything up for tomorrow, I ran into a snag- the tablet mount that came with my Tacx trainer is designed to mount right where my clip-on aerobars mount.
Does anyone have a clever way around this? I saw DCR’s homemade stand made from a mic stand, so I guess that’s a cheap option. Has anyone else found other solutions?
Ghanks
Hi All,
Ghanks
I also copied the mic stand and it worked well. Just upgraded to the Wahoo desk. Nice quality and just a couple of minutes to set up.
Built this stand out of some 1 1/2" PVC pipes and a chunk of spare plywood. Super-easy to do, cost less than $15 and took me about 30 minutes to put together. I have since lowered the height so that the table is below my brake levers.
http://i36.photobucket.com/albums/e15/Power13/IMG_0087_zps0niwmvw8.jpg
Can you offer up your plans/ measurements for this?
Bought this on Amazon for about $30. Let’s me watch TV and use my iPad for Zwift
https://www.amazon.com/gp/aw/d/B00HFRYA7U/ref=yo_ii_img?ie=UTF8&psc=1
Did the same thing but got this one since there was a shelf near by. No floor space required. Hangs from above
$25.
Works pretty well. Once I figured out to put the clamp on opposite corners of the iPad and not the sides. Operator error for sure.
https://www.amazon.com/TaoTronics-Universal-Sturdy-Aluminum-Tablet/dp/B01E8QBOCY/ref=sr_1_17?s=pc&ie=UTF8&qid=1484581342&sr=1-17&keywords=iPad+mount
I also have a Tacx tablet mount (got it off of another ST’r in the classifieds). I also ran into the can’t mount it on my aero base bar (even if I could I wouldn’t be able to use my aerobars…so kind of a no go for TT bikes).
I made my own franken setup like so:
http://i.imgur.com/UBKSB5V.jpg
http://i.imgur.com/fWQgyb9.jpg
Got an alloy adjustable flagpole (off of amazon, was $7) and some sch 40 PVC pipe (3/4" so the OD is just over 1" and spent like $5). Mounted it to my treadmill frame using industrial rated velcro (aready had some on hand), duct tape and some bungee cords (as a 3rd line of insurance). That way I can move it out of the way. I have it setup like this because sometimes I swap out my Fluid trainer for rollers.
I also opted to not mount it to the wall because I didn’t want to drill into that and make it something permanent.
What I really should do is drill a through hole and a put a bolt to have an anchor point to keep the mount from rotating (it isn’t a super tight fit, even with a few turns of duct tape to increase the thickness of the pipe). It works though and my only wish is I have a bigger tablet screen (have a Nexus 7 but it works well enough…use bluetooth headphones to hear better over my cooling fans).
Side note, previous owner’s of my house had a dog and that stain on the carpet next to the treadmill was there prior to me moving in. Tried to use a carpet cleaner but it is still there. One of these days I’m getting new carpet down there but only after I fix some other things first…sigh, the joys of home ownership :frowning:
Hi All,
Ghanks
I have the Mic stand with a Nootle Tablet holder. It works amazingly well and looks good too.
http://www.grifiti.com/products/nootle-ipad-tripod-mount-2-3-4-retrofits-tripods-stands-photos-displays
I use my phone, not a tablet, with TrainerRoad.
It sits in a little plastic Glad Wrap box stuffed between the aerobars.
Sent you a PM…
Thanks, All.
So, it looks like the consensus is ditch the Tacx mount in its current form for a homemade setup that works for me. Sounds like pretty good advice!
