More inner tube rolling resistance data
Dan asked me to post this data once we’d got it, this is updated with a load more butyl inner tubes as well as a few different latex ones. I know everyone will give me grief as the Silca latex tube isn’t there but we couldn’t get one in time, we do plan to test it! As well as Vredestein.
INNER TUBE DATA
What I found interesting was the Conti Supersonic (my word it’s thin!) beating out the Tubolito. Personally I think the Tubolito would be a better choice out of the two as it feels more substantial. As the Conti range got lighter/thinner they got faster, no real surprises there but latex is much better overall. The Michelin latex tube does feel thicker than the other latex tubes, and so that may be why it tested slower - interestingly the Challenge tube was a little undersized diameter wise when inflated (unlike most other tubes), perhaps something to do with losing the seam as it’s seamless (unlike the Michelin/Vittoria).
Aren’t the Silca tubes just rebranded Vittoria tubes? Or are they just produced by Vittoria but spec’d differently?
Looks like you might be right actually - they do look the same having just Googled it although I thought there was a different version out there for some reason. The Bontrager tube seems to be rebranded Michelin so we didn’t bother getting one of them.
Josh talks about the Silca partnership with Vittoria. What is interesting is that Vittoria appears to have started adding Graphine to their latex tubes, so this year’s model has a slower leak-down rate. Not that I want to suggest more work for you, but the interesting comparison would be the Crr of the graphene/nongraphine tubes.
Thank you for the info
I’m happy 😃
For once I actually have the fastest item and don’t have to buy something different lol
This year as in 2019? We get all our Vittoria tubes straight from the distributor (as we recommend/spec them on our wheels) so they are the most up to date ones we can get hold of, and consistently buy a lot of them too. I’ll ask though!
INNER TUBE DATA
Great data! Thanks for providing.
I’ve been using the Conti Supersonic tubes as race backups. They are so thin they pack down really small so you can pack 2 easily.
thanks for the info!
Not terribly surprising overall, but good verification!
Interesting info.
About the Challenge Tube. I had a flat a few weeks ago with a Vittoria tube that has been in use for 3 years. My spare happened to be a Challenge. My issue was with the circumference, it was small. It was like stretching a rubber band around the rim. I absolutely could not install the tire without pinching the tube until I stretched it overnight so it would fit up into the case of the tire better.
My next order will be for the Silca tube.
Interesting info.
I bought a pair of Challenge latex yesterday and searched a bit in the internet when I came home and read some reviews of poor quality of them. I went back to the bike shop and was happy they took them back.
Interesting info.
It’s odd isn’t it - not usually what happens when you pump up a tube, luckily it didn’t pinch for this test! We’ve been getting a bit of feedback elsewhere that people don’t like the current Challenge latex tubes, personally I’ve used them briefly years ago but not recently.
INNER TUBE DATA
Yeah…super-lightweight butyl tubes are basically a “worst of both worlds” type of situation. They’re still slower than latex, AND they snake-bite flat even easier than regular butyl :-/
As was pointed out though, they DO pack down quite small…so, like the Tubolito, their best use case is really for a lightweight flat kit.
Honestly I don’t really want to know. It is always bad to find out that the old stock is faster. Then you end up spending tons of time trying to locate old product. Sort of like the 2nd generation Conti SS 700x20 tire for the H3. You can find the high Crr Gen 1 and the fatter Gen 3, but the Goldilocks Gen 2 is getting really rare.
Hello Xavier and All,
Thanks for posting.
Now I do not have to buy new inner tubes.
thank you, it’s always good to have data…
i have always wondered for full distance ironman, since the bike leg take quite some hours to complete. does latex tube need topping up… or latex almost guarantee puncture over that distance i.e. need pumping up anyway lol.
If anything, latex seems more resistant to punctures than butyl. I’ve only ever had to stop once to fix a latex puncture, and it was when a stabby thing punched a half-inch gash through my tire; butyl or tubeless also would have been toast.
It’s a good question, something we get asked quite a lot by IM triathletes. You’ve got three options really:
  1. Actually measure the real pressure difference over 3,6,9,12hrs by pumping up your tyres at home and seeing how much they go down (won’t be universal as it depends a bit on your starting pressure), then overpump when racking your bike to compensate
  2. Add 5psi and hope for the best
  3. Don’t worry about it
Most people go for option 3 :smiley:
Very interesting, thanks for sharing.
Are anyone, Michelin, Vittoria, Silca etc. making longer lenght valves latex inner tubes? One of the hassles with latex tubes is the need to use extender etc.
Xavier,
Since I have plenty of the new ones at home in both sizes (19-23 and 25-28) I can confirm the pictures in your article do not show the new Vittoria.
The new ones are called COMPETITION LATEX and have an alloy valve core, making the 19-23 version pretty light at 62 grams. The one Latex tube I have that is lighter is the Vredestein at 52 grams with a brass valve core… so super thin ! I tend to like the Vittoria with alloy valve core and the Silca more than all the others…
Links to the new ones :
https://www.probikeshop.com/en/gb/vittoria-competition-latex-700x19-23-inner-tube-48-mm-valve/158827.html
https://www.probikeshop.com/en/gb/vittoria-competition-latex-700x25-28c-inner-tube-48-mm-valve/157443.html
Hope this helps.
Thanks again for a great article (and answering my CRR question on Facebook :wink: ).
