Maurice
Thanks. Great to hear.
So you could fly directly to Maui, for the day, do the climb and be back out?
Just ride your bike to the KOA airport check in your bike at the airport by removing pedals, deflating tires, turn handlebars , arrive in Maui, put pedals back on, inflate, fix handlebars, ride up Haleakala, and ride back and reverse the process? How long out and back is the official climb to the summit from the airport. Would 6 hours cover the entire bike of adventure?
The issue with the flights (as far as I remember) from Seattle, Bellingham, Vancouver are that the usually get to Maui in the evening between 7 and 10pm if you are flying there direct first. Not sure though because it looks like you will go to Kona first?
I would maybe fly in (get airport hotel) and leave early the next AM, then get a puddle jumper to Kona that evening?
In terms of time 6 hours is crazy tight, for reference a month ago I went 3:53 up, another local guy went 3:43. I am in about 5:25 IM shape and he is in about 5:10-5:15 shape, My girlfriend went 4:30 or so on her 23 pound (with water etc) cervelo P2 ALU, and a few days later went 4:06 on my bike with me carrying her water (I have a soloist, around 14lbs) for the same effort she was 24 min faster with about 10 pounds less!!!
3:43 took him about 200-210 watts, he is 158 lbs and rides a 13 pound or so EVO (with a power tap!!) the grade is a steady 5% but as you get above 7000 feet it feels more like 7-8%
The issue is the downhill, it is cold and can be a bit slow, I was shivering and had a bit of trouble braking. For our “all out attempts” we went minimal up and hitch hiked down.
So up and down from Paia might take you 6 hours without stops for picks etc add another hour or so from the airport and you are cutting it tight with no room for a flat etc, I would say minimum 8 hours unless your name is Ryder.
Cheers,
Maurice
