Marathon Heart Rate
Out of curiosity, what HR range would one expect to maintain for an all-out marathon effort? I’ve run several but all before I began HR training. I would guestimate based on RPE that I would have been primarily in zone 3, moving to 4 toward the end. I would like to qualify for Boston this fall, and I think using HR training would be a good gauge of my progress in terms of pace vs. heart rate/zones.
Anyone have any personal data they would like to share, or know of any published information on the subject?
You should race a marathon by pace, not HR, as by various reasons, the HR creeps up during the race.
In my case, I started out my last marathon around the top of Zn2 and ended up more then 10 beats higher than my LTHR, well inside Zn5.
I found this online. Sound about right to the ST coaches?
coaches corner
by Kirt West
Follow Your Heart to a Marathon PR
In my summer footnotes column, I outlined a program for running your first marathon with a heart monitor. This column offers an alternative for those frustrated veteran marathoners whose times do not correlate with their race performance at shorter distances.
How do you know if you are one of those who should try to run their next marathon using heart rates? First, consider this method if your marathon times are significantly slower than your results in shorter races. You should be able to run a marathon at a pace of one minute per mile slower than your 10K race time.
Even if you have a gap of more than a minute and a half between marathon and 10K times, you need to look for defects in your training before considering using heart rates. Did you do long runs up to 22 miles every other week for a 12-week period before the marathon? Did you do any training at Predicted Marathon Pace (PMP)? Did you do any speed work such as anaerobic thresholds at 80-85% of maximum heart rate (MHR) that equate to your 15K or 10-mile race pace? Were your recovery days at 60-70% of MHR? Did you taper down at least 3 weeks before the marathon? Did you go out too fast? Did you get dehydrated during the race?
If you are convinced that neither training nor mistakes in race strategy caused your slow marathon, then the heart rate approach might be for you. You may get so nervous about the marathon that you completely psyche yourself out. Or you may have problems with pacing.
Caveat: Racing a marathon by heart rate might not provide the results you are hoping for. If you embark upon this endeavor, your goal will be to match your goal pace with heart rate. This is not easy, because doing training runs at PMP is not the same as what happens when you pin a number on your chest and enter a race. My information on this subject is anecdotal and results are greatly varied.
To prepare for your heart-rate marathon, incorporate several PMP runs of 5-12 miles into your long runs. Because this kind of training can really beat you up, you should take off the days before and after one of these demanding runs and do no hard training runs 3-4 days before or after the PMP run. As you run, you must get feedback from your heart monitor and observe how much your heart rate increases at PMP. These numbers will be critical in determining what heart rates to use in the marathon.
Your marathon effort should be in three zones. Zone 1: Try to run at a constant heart rate for the first 13 miles. Zone 2: Miles 13-20, strive to increase your heart rate by 3-4 beats. Zone 3: From mile 20 to the end, increase rate another 3-4 beats. Zone 1 will be approximately 80% of MHR (using the Karvonen formula described in my Summer footnotes column). Zone 3 will be 85% of MHR; however, do not arbitrarily set Zone 1 at 80% because your anaerobic threshold can vary depending upon your level of fitness and may be higher than 85%.
Once you have determined these numbers, find a relatively long race, at least 10 miles, preferably a half marathon, to test them. You need to be totally rested. Try to run the entire race in Zone 1 to see if the pace gives you the results you are hoping for. Running a half marathon or 10-miler at this effort level should be somewhat easier than racing it at an all-out rate.
I would appreciate feedback from any readers who have run or plan to run a competitive marathon based on heart rate.
Coach Kirt West is a private coach for motivated adult runners and a member of the Montgomery County Road Runners Club. Questions for him can be sent to kirtwest@erols.com
I’ve run every marathon by pace, but if you target a pace that is too fast or too slow, you’ll likely have sub-par results. If a 6:35 pace for me is currently run in zone 4 (which it is) obviously there will be problems if I tried to hold it for a marathon. I’m trying to find a way to determine the pace that is maintainable for the full distance without setting myself up for failure.
I’m guessing that if by race day I can maintain a 7:10 pace and stay under 80%MHR for the first half, I should be able to qualify with a 3:10.
Running it by HR can be even worse.
I would advise you to use Daniels’ tables of equivalent performances to setup the right pace for your marathon. If you do your training right, those tables are very accurate.
Thanks, I’ll check it out. I’ve seen the McMillan version (www.mcmillanrunning.com) but not Daniels. Google didn’t give a direct link, where do you find it?
amazon.com
I think it’s funny is that everybody is recommending that people pay good money for a power meter (I ordered one yesterday), but when it’s for free in the form of pace, nobody wants to use it.
The increase of your HR during a marathon is dependent on so many things, it’d be hard to put accurate numbers on it.
46yo male 3hr thons equal 161 ahr…max is 189 …4 qty
??? you’re a 46-year-old guy who’s done a 3-hour marathon (it’s ‘mary’) at an average HR of 161. confused,
I agree with Paulo. In running especially, HR isn’t that important: What training and racing can your legs handle? Never seen a really fast guy run a race with a HRM.
Nothing wrong with training with one, though.
I like the HR monitor to keep me under my anaerobic threshold for the first bit of the race when adrenalin is high and I might go out too fast, but after that, it’s all about the pre-determined pace.
