Magura RT8 TT Hydraulic Rim Brakes/Levers/Fittings
One full set of Magura RT8 TT brakes/levers/parts in excellent condition. Includes all parts/fittings needed to set up and maintain these brakes on your TT bike.
$350 plus shipping. Paypal or Zelle only, no Venmo payments.
  • Pair RT8 carbon levers, flawless shape
  • Set front/rear RT8 calipers, includes frame mounting bolts and M8 compression sleeve nuts. Pads/holders/washers not included.
  • 3ft used hose; cut to use on front brake
  • 6ft unused hose
  • 6 compression olives (goes in caliper, one-time use)
  • 6 barb fittings (goes in lever; can be reused with some difficutly)
  • 16oz. Magura Royal Blood mineral oil.
  • Bleeder syringes, one each for lever and caliper
  • Spare lever bleed port screw (plastic, tighten carefully)
Manuals available here: MAGURA RT8 TT OWNER'S MANUAL Pdf Download | ManualsLib
Installation guide: Magura RT8 brake How-To - Slowtwitch News
Bleed tutorial: https://www.youtube.com/watch?v=LN4wbeTFVYY
Still available?
Did you ever find out if they’re available? Any luck finding another set? My build is dead in the water and I could really use some levers at the very least.
Thanks
How serious are you about getting a set of Magura RT brakes?
Where are you located?
