Your numbers make no sense. Want to try with some real ones from real bikes?
Sure, want to try my bike fit?
Fit = 681 stack, 414 reach to back of pad.
A middle of the road stack - reach bike is the p2.
Look at p2 geometry chart. http://www.cervelo.com/...9-7343cad65732-0.pdf
56 frame has 531 stack and 429 reach. So I would need 150 in stack added by the system, and -15mm of reach.
You can get kinda sorta close if you jerry rig the right stuff. But not awesome.
A fairly high stack bike is the Felt B.
Look at a Felt B 56cm http://www.feltbicycles.com/...ilable-in-650c-.aspx .
420 reach, 554 stack. So I only need to add 130 stack with my system. And I need to only add -6mm reach.
So play around with spacers and aerobars and stems, but at the end of the day I have less spacers going on with the Felt, and I am less behind the basebar with the Felt.
I think there are bikes that are even lower and longer than the P2 that would show the example even more clear, but I just spent some time playing with numbers on these 2 bikes…
I don’t actually know anything about bikes, but have spent the last month playing with numbers and looking at bikes, so it is kind of sucked my brain over. Really hard to sort through all the data, because you have 10 % of the people telling you “always get a Cervelo, its the best”, 10% telling you “Always get a Felt, its the best value”, 10% telling you things that make no sense, etc.
My info my be totally wrong, but it is the best I can come up with playing with bikes and stems and tape measures. If there is a magic way to put the cevelo p2 at my same exact coords, and handle no worse than the Felt B, then I wasted a lot of brain power for nothing. I did not find this magic way however.
