Any suggestions on a low stack , long reach road bike ?
Specialized Allez could a little lower and a lot longer, 140 stem on there now.
Thanks
Thanks
Boardman bikes might fit you well
2016 Cervelo S5
Specialized tends to make the top tube about 0.5 cm longer that the “seat” tube. For example, my Venge is a 54.5 top tube for a medium/54. Then you can do the flat bars on the VIAS or pull the aero spacer on the regular Venge and you will be pretty long and low.
Thanks
A lot of the Allez’s are notoriously tall (the DSW is pretty low), so theres a good chance nearly any other bike will get you where you want to be.
Felt F-Series is one of the long/lowest around
Don’t know your size but this comparison should be instructive
http://i64.tinypic.com/258y0hv.png
Other options:
Boardman SLR
Trek H1
Vynl Alloy Road
Eddy Merckx San Remo 76
I say Trek H1, I think Focus and Felt tend to be pretty low stack as well.
Fuji
Focus Izalco
