Like other people have said, you can’t cut your calories in half and survive. Your body will go into starvation mode and you’ll gain weight and it will be a disaster.
500 calories a day is the largest deficit to run safely, and a little less is better. I am a similar profile: in my early 30’s, 6 feet, 175 lbs. In college, I’d race at low 160’s and so now it’s always frustrating to be in the mid 170’s. That’s partly just getting older though. But I’ve been able to cut back down to 165 again this summer, in time for some “A” races in the late summer and through the fall.
A few tactics that help me shed those final ten pounds; I use these safely and effectively: My major points:
- Remember that getting those “final five to ten pounds” is a long-term process. It SHOULD take two months or more.
- Do a workout first thing in the morning – without eating beforehand!! (this is important). Black coffee beforehand is fine and probably helpful (and it has basically zero calories), and water during is fine. Then eat a healthy breakfast afterwards. Combine this with an occasional double session day.
- Set a time when you stop eating at night. 7 pm is a good one. It will be tough for two days, then will get easier. You’ll sleep better and wake up more easily. You may have water after 7, but nothing containing calories.
- Eat carbs, protein, fats throughout the day, but a higher proportion of the carbs earlier in the day.
Other:
- Cut out junk food and candy. No empty calories, refined sugars; no fast food; no regular soda; no high-fructose corn syrup.
- If you drink, limit alcohol. A beer or wine are fine – you’re an adult. But limit to one a day (make it a good one!), and only a few times per week.
- Protein is important; don’t avoid carbs unless you have legit gluten issues, and if you do, eat safe carbs.
- Don’t avoid fats. There are healthy fats.
- See a nutritionist if you’re financially able to do so. You’ll learn a lot. Read reliable nutrition information sources (anything by Nancy Clark is highly recommended: http://www.nancyclarkrd.com/ and geared towards athletes.)
- Lift weights; 10-12 reps per set. You must maintain muscle mass.
- Don’t just do long slow-distance-workouts; you’ll lose too much muscle mass and get slower. Keep mixing it up and doing speedwork.
- If you typically gain weight in the winter (I do, 5-10 lbs) try to be aware of this and limit it. Doing so helped me a lot this past year as I began slimming down for the summer.
- Give yourself an occasional normal day where you go out to dinner with people or take a one-day break from the diet – without binging. Positive mood and happiness are important and can actually help you lose weight.
The two books in the “Racing Weight” series, published by Velopress, have some good workouts in them and discuss much more. I recommend them.
You’ll be amazed at what a five to ten pound loss can do for some people. I also recommend that you consult knowledgable friends or a coach, and try to make sure you’re being safe. Also, don’t advertise your diet too much; you don’t want to be someone who seeks attention or praise for it, as people will find it very annoying. Further, your wife or close family/friends may be really put-off by it, or may pick up some unhealthy ideas or “food issues” (ie: anorexia). It’s a fine line to walk when you try to do this safely, and some people go way overboard.
Finally, remember: you’re doing this in order to achieve better race results, not to lose X-number of pounds or to look a certain way. Don’t lose sight of this! There will be a finishing point where you’re at an ideal, and where going further will make things worse.
Good luck.
This is all very good advice apart from:
Losing muscle mass is not neccessarily a bad thing, ONLY if it is affecting your performance. Most people carry unnessary muscle mass, especially in the upper body. Look at the ITU (even Long-course guys). Moreover LSD won’t make you slower, speed is easy to gain, aerobic fitness is much harder and takes longer that’s where LSD comes in. With LSD it is easier to run a big calorie deficit than harder more intense workouts, most cyclists lose the bulk of their winter weight during the base LSD phase.
1500 calorie deficit (to the OP) is plain silly/dangerous. No more than 500 a day!! It’s a long term process, best advice I can give is weigh yourself every morning, go to bed a little bit hungry (I don’t bother with calorie counters), if you’re not hungry for breakfast when you wake up you’ve had too much dinner.
It’s worked for me, bottomed out at 7.5%BF (19.1mm sum of 4 skin fold, none of this ST underestimation) my twitter pic is of an early season race at 8.7% 183cm at 67.7kgs (that pic makes my arms look huge)
Remember it is a long term process, I have no issue with having something sweet every now and then, calorie deficit is king.
