Chemist
September 17, 2022, 5:28pm
1
I’ve had the Altra Escalante (versions 1, 1.5, and 2) in my shoe rotation for most of the past 5 years. I really like them. They just seem to have of cushiness without feeling like I am completely walking on clouds or and a good amount of flexibility without being too unstructured. I like the knit upper, but would be fine with a regular upper as well
What I’d like to get is a shoe like this but something that doesn’t have zero drop. I’ve been using zero drop shoes here and there for over a decade, but whenever I start back up after a break it’s a bit harder to get back as my Achilles don’t seem to be as resilient as they were in my 20’s.
Escalante Stats:
Midsole = Altra Ego (not sure what it is made of)
Stack = 24 mm
Some shoes I have used recently:
Saucony Endorphin Speed = ok if I was doing fast runs on pavement. But for a daily trainer want something without a plate. And they felt a bit tall and narrow so I was never comfortable jumping on some trails for part of the run
Nike Pegasus Turbo 2 = one of the best shoes I’ve ever had but they don’t make these anymore and apparently the new turbos are not quite the same
**Nike Air Zoom Tempo Next **= one of the worst shoes I’ve ever worn. One of the only times I’ve ever returned a shoe
Hoka Mach 4 = I kind of liked these. What kept me from loving them is they were a tad on the tall side (30/35mm) and they felt a little clunky - I think this was due to the width of the sole - it made it hard to venture off onto trails/uneven surfaces
**Hoka Bondi (6 I think?) **= hated these, too tall and to soft. Gave them away after 100 miles.
**Sketchers Go Run Ride 8 **= had picked these up since they were on a blowout sale. Like the Mach 4 I liked but didn’t love them. They were at the upper limit that I’d like in terms of stack (24/30mm).
So I guess something with <30mm stack, a drop of ~4-8 mm, a midsole with similar feel to Altra EGO. I’m a mid and forefoot striker if that matters. Any recs of what to try out are welcome. Thanks!
Chemist
September 17, 2022, 6:23pm
2
Just glancing at stack numbers running warehouse some of these might be possibilities?
Brooks Hyperion Tempo (maybe to performance oriented for an ‘everyday’ zone 2 type of shoe?)
Brooks Levitate 5 (weight is a bit higher than what I’m used to)
New Balance Fresh Foam X Tempo (not sure what the stack is…looks lower than the fresh foam 8 and 10 series which would be too much for me)
Saucony Kinvara 12 (I worked one of the early versions 10-ish years ago and thought it was alright, wondering if it’s as narrow feeling as the Endorphin Speeds)
verry polarized shoes you are looking compared to the altras. I guess the hyperion tempos come closest. Most thing I like about altras is the wide toe box
I’d say head to the LRS and try on a bunch of stuff.
some other shoes to try
Asics Noosa tri 5mm or 6, I think 5mm stack - we can not keep this shoe in stock though. Asics novablast 8mm although I think this will be too springy for you. I think the Asics you’ll really like is the magic speed. 5mm.
Brooks launch 8mm, although I think the Hyperion tempo, also 8mm, is a better choice.
NB tempo v2 6mm
NB 1080 but I’d be less inclined to say this will be your shoe vs other on the list
Hoka Rincon 4 or 5mm might run into the same problems as the mach’s.
saucony kinvara
mizubo wave rebellion 8mm although I’m iffy if you’ll like this, actually I’ll bet you $10 that you don’t.
Hope that helps, lmk if any questions
drn92
September 17, 2022, 7:50pm
5
I’d check a couple Topo shoes, they may fit the bill. Lower drop and wide toebox.
drn92
Chemist
September 17, 2022, 7:57pm
6
Thanks for the recs Brian. I was planning on heading down the the LRS next weekend to try some out. But I get a little overwhelmed if I’ve got too many choices so I figured I’d try and pair it down a little bit before hand.
For whatever reason Asics hadn’t been on my radar at all even though I did get some Metaspeed to race Boston in (depending on where the cutoff lands). Have not gotten a chance to use them other than running around the store a bit but I think I like their fit better than the the Vaporfly’s I’ve been using. Perhaps maybe the Magic Speed would be a good training shoe ‘match’ to it. Looking at the design of the Noosa Tri, I’m pretty sure my 3 year old daughter would love it if I got that shoe. haha
have them bring out 5-8 choices. try a pair on if you stand up and don’t like how it feels put it back in the box & rule it out.
If you like how it feels, run around the store. If all good set it aside for later.
Go to the next pair. Same thing, Y or N
After you get through them all now put 1 shoe from pair A on and a shoe from pair B. See which one you like best. take the other off and reject those shoes.
You’ll get down to 1 or 2 pair that you really like. If you’re at 2 pair and really like them both, you don’t have a bad decision in front of you. Buy them both or buy the coolest looking one and write down the other one. Then in 2mo go get that other pair to add it into the rotation.
hope that helps
It sounds like you and I have similar preferences in running shoes. I LOVE my Nike Pegasus Turbo 2s, and I have a small stash built up, some bought on eBay. However, I’ll have to switch soon enough. My requirements are cushioned but also lightweight. I find heavy shoes can lead to pain and problems with the top of my feet, even if they’re cushioned. Nike doesn’t have a true replacement for the Turbo 2s. Their cushioned shoes using the ZoomX foam are mostly significantly heavier than the Turbo 2s.
I looked at the weight of a bunch of shoes described as “cushioned” or “soft” from various brands. This is the list I came up with. I’m curious about the Turbo Next Nature. I think the Nike Streakfly is probably too light to be adequately cushioned, but I might give it a try. I think otherwise, I might try the Hoka One One Rincon first. I tried Asics’ cushioned trainer but found it too unstable for me.
!(data:image/png;base64,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)
dcolv
September 18, 2022, 4:33am
9
Love altras for the toe box as well, but they don’t give enough impact protection for me.
So sounds like we are similar. I wear the altras for my daily walking, office, errand, whatever shoe.
Hokas really have hit the sweet spot right now. The shoes are lite weight and the foam is just right for cushion and springiness. From trialing several pairs the Mach 4 and Rincon 3 are my favorites. I see about 300miles out of a pair before I really start to notice the foam is dead and my feet and joints tell me the same. So not super durable but the rincons are reasonably priced.
I went through two pairs of Mach 4 and ultimately noticed it runs narrower and that’s why I switched to the rincon 3. The upper allows stretch and my toes stay happy.
The rincon 3 and the newer Mach 5 are both available in wide width. I haven’t had a chance to check those out yet but they are on my list.
