Total: 186
LDL: 116
HDL: 63
Triglycerides: 33
Chol/HDL Ratio 3.0
LD/HDL Ratio 1.8
VLDL: 7
tested apoB but don’t see number in online portal
Metabolic panel all normal range.
Calcium scan & trans echo next week followed by coratid artery scan following week.
Thoughts on numbers? Bad or meh.
Note: I have a good doc and meeting with him next month to review. I did nuclear stress test & echo, etc three years ago and I was clean. Posting my lipid panel because lots of good discussions from medical community on here. Not looking for podcast pseudo science advice.
I’ll be interested in your apo-b result. Your LDL is higher than the classic “keep it under 100mg/dl” recommendation while your triglycerides and HDL look excellent.
me too. will circle back w update. going to try and lower with more thought re food choices in addition to whatever rest of tests & doctor recommends. 48 years old, fit, but family history of heart issues…
CT Heart Calcium Scoring = 0. I have a coratid scan set for the end of this week. Do i need this if I received a Calcium scan of 0??? The coratid scan was at my request. Still do not have an apoB number.
Mine, from today, is markedly similar to yours. My VLDL is slightly higher. I had not heard of and see no sign of a apo B test . . . could it be labeled something else?
I just looked back at my blood profile results and see that it took 5 extra days beyond when I received my basic blood panel results, which came the very next day, until my apo-B results to come in. Apo-B is short for **Apolipoprotein B-100. **
No. I feel fine and I’m fit. That aside, my father had a heart attack in his 40s and quad bypass at 50 and stints later in life. I’m on the doorstep of 50 (almost 49) and making sure I’m the first male in my family to hit 50 without a cardiac issue.
but FTR, a calcium score of 0 is super powerful information that your cardiac risk is indeed VERY LOW.
The cor score can be used with the MESA calculator to get an idea of what percentile you fall into. AGE 48 is 35th percentile with a 0. *(if you are white)=very good.
