I am looking for full length leg warmers - anyone have a tried and true brand/model? These would be for days when I feel I need full length coverage but don’t want to get out the bib tights. Probably 25-45 degree wearability.
How do they generally fit? (I’ve seen several models list total length…but it seems like based on that it would run pretty high up the thigh??)
Pearl Izumi is always a good standby for this sort of thing. Plenty of people make them but PI almost always gets it right.
They should fit mid thigh if not a bit higher. You want some coverage for your thigh as well.
I don’t think leg warmers are going to work to 25F. If nothing else your chamital area is going to freeze and fall off unless you pair them with some thermal shorts, of which I’ve become quite a fan.
I have two pair of relatively inexpensive ones. One pair from Descente, and one from Bellwether. They go from ankle, almost to the hip joint, but I have a pretty short inseam and very muscular thighs so I had to size up a little.
I think I will answer with what I actually wear here in WI where it was 36 degrees F this morning. Your smart a** question was not lost though.
Cycling shorts with back long underwear over them (some times I use my cold weather running tights)
Under armour cold gear turtle neck, long sleeved t-shirt, cotton turtle neck, light neon green wind breaker
Levis grey socks, Tri-shoes, PI toe cap warmy things (wife took away the cut-up old socks I was using and bought me these)
Manzella hat, bike helmet, Oakley M frames
Toasty warm for a quick 1:20 ride before the sun came up.
There is no fashionable answer. Tights, or cycling leg warmers look the same. Leg warmers are significantly less expensive and give you options if you live in a place where the day may start at 35 and finish at 60 degrees.
In the end, we’re all wearing spandex and look stupid.
Ha-ha neon green, I wear thermo pants under Adidas sweats a Spyder or adidas compression under shirt with a sweat wicking shirt over top, Giordano jacket, Goretex gloves, Bolle vigilante glasses. Okay I also have that neon green 1980’s looking jacket that I break out when its dark in the morning. Need for warmth overcomes the need for looking good and the extra drag from the weight of the clothes and baggieness benefits my workout also. It’s sort of like wearing ankle weights when you run and then taking them off later.
Anyone tried the Assos leg warmers?
We’ve sold some Assos stuff in our store and while it’s really nice, I can’t see spending that much on leg or arm warmers. Those items just aren’t complicated enough to be that expensive.
Here is a link to some full length mens ‘Zoot’ leg warmers(XL size only) I have for sale. They have zipps on the ankle region also. They are only $17 USD at present and includes postage and packaging. Am going to write on the page soon that the minumum order is $30USD($50NZD).
Ok, here’s the deal. If it’s cold out, wear tights…they just work better.
The only use for leg warmers and/or arm warmers is when the start of the ride is cold enough to need coverage but the end of the ride won’t be. Their sole purpose is to be removable during the ride.
If you start out in the morning when it’s 45 and finish later when it’s 70, then warmers are the ticket.
I don’t see them as a cheap replacement for good cold weather gear.
