Been doing tri for a long time and never learned how to flip turn. Thinking of learning this as I was told the sensor on my VM will detect flip turns better than open turns. Does it generally take a while to learnt the flip turn? Or is this something I can do in a weekend with a little dedication?
When I learned how to turn 30-some years ago, I learned the basic movement in about 20 minutes, IIRC. we took out part of one practice to learn them. I was reasonably proficient, meaning that I could do an entire practice without missing the wall or hitting my heels on deck, after about 3-4 months.
I spent 5 years before I was “good” at them, meaning that I wasn’t losing time to my peers in races.
Not to disuade you from learning flip-turns…but, it will take a while (more than a weekend) in order to be good enough to do them so that the watch detects them consistently—you still need the hard push-off to trigger the G-sensor. You will probably miss more flip-turns (turning too soon, turning too late, lopsided, too deep, etc) than your watch is currently missing your walls…for a while.
I have a garmin (not a Polar), but I used to have issues with it missing walls on open turns. What has worked for me is simply getting more proficient at open turns. I try and lose as little time as possible to the flippers. I swim hard to the wall, touch with my non-breathing side hand, recover my breathing side arm and touch (both hands on pool edge), pull legs in, squat and push-off hard into my “best” streamline.
I use walls as a chance to work on streamlines, and breakouts…just as a skill to have. So, I’m sure to push off hard, so that I have some “speed” to work with and preserve as far as possible. Since I started making that effort, my Garmin hasn’t missed a length.
Again, I’m not saying “don’t bother with flip turns”. I’m just saying it won’t be a miracle solution after 30 minutes in the shallow end of the pool. If the only reason you have ANY interest is for your watch…there are probably better ways to solve that problem.
I took a 1.5 hour flip turn clinic put on by a local swim coach. I had attempted a few before but had given up on them. The clinic gave me enough to start working them into my workouts. I took about a month to work them in, starting with doing them in warm up sets. It took a while to do them under hard efforts (100m fast sets etc). and my technique still gets really sloppy when I’m tired.
General progression of the clinic:
-stand in shallow end and perform complete “roll”
-float stationary on stomach, and initiate complete roll
-float stationary on stomach, and initiate half roll, to finish facing “up”
-float stationary on stomach, with fingertips touching wall, half roll, plant feet.
-put it all together moving slowly.
Also, watch some youtube videos!
FWIW, my garmin 935 is very consistent with picking up turns, whether I do open or flip. I think a strong push is the key though.
I don’t have that watch but I would think it can handle either, because not all sets are freestyle.
Yeah, that’s the only time I’ve had issues with it counting, once in a while it registers an extra length when i switch strokes, usually mid-length
Yeah, it’s got about one or two more chances while the return window is still open. Customer service has been less than stellar. If I can’t get it to work this weekend I don’t care how much money I saved and how good Flow is I’ll be getting the 935.
After 4 years in the sport, I decided I needed to learn. It took me a good 6 months to really master them but it has paid off for many years now. After listening to useless advice from all the masters swimmers in my pool, I was able to self-teach using the very basic, Go Swim series on Youtube.
Lesson 1 - https://www.youtube.com/watch?v=YFQpLyihI5M
Lesson 2 - https://www.youtube.com/watch?v=ryN-4R1E8d8
Lesson 3 - https://www.youtube.com/watch?v=fHXNBbLFiJs
Lesson 4 - https://www.youtube.com/watch?v=KNQh2SqA2Ck
Lesson 5 - https://www.youtube.com/watch?v=Ss6-htcF9mA
I thought that was a good tutorial with a logical progression. I have started practicing a bit just to break up my swim sets.
Yeah, it’s got about one or two more chances while the return window is still open.** Customer service has been less than stellar.** If I can’t get it to work this weekend I don’t care how much money I saved and how good Flow is I’ll be getting the 935.
Dude. Lighten up on Polar. At least until you figure out if its you or the watch. Apparently they gave you a deal (according to your post up top), and have given you suggestions for how to get it to work more reliably.
If you really think Polar Customer Service is giving you the shaft, then be specific. But all this veiled, non-specific, “…less than stellar” crap comes off wrong.
As was mentioned above, it was pretty easy. This is coming from a guy who started swimming @ 2:20/100 and had very little swimming ability. After swimming for about 2 months, I decided I needed to learn how to flip turn. Seemed important at the time?
I actually learned almost all of my swimming from Youtube, how to breath, how to perform all the mechanics of the stroke, and ultimately how to flip turn. I put into practice what I learned, and in about 20 minutes the first day, and 10 minutes the second day, I was doing flip turns on most of my lengths of the pool. Within a few weeks, I would do them regularly. I essentially started with the following progression.
- Stand and attempt a flip
- Take a step forward towards the wall and flip (but not touching the wall)
- Swim and then flip (not touching the wall)
- Swim and then flip, attempting to push off the wall
- Flip turn success!
After all that, I’ve stopped flip turning. I actually prefer not to anymore, because I do a lot of sets with paddles and PB, and I don’t really like to flip turn with paddles on. So I just find it easier to never flip turn. I suppose I just need to learn to flip turn with paddles on, and then it would all be second nature too.
Good luck, it’s really not that difficult to learn if you put your mind to it.
Ok, more specific. I’ve sent two emails neither of which were answered, factory reset my watch twice, called and told to hit the wall harder by a guy whom I honestly couldn’t understand over a thick accent, sent a message to Facebook that also said hit the wall harder.
As far as returning goes my window closes March 28th and it’s March 13th. Unless all facets of the watch work by lets say March 20th I’ll have to go in another direction.
However other than the swim problem (which is a dealbreaker) I actually like the watch. It’s good looking and I enjoy Polar Flow. I’m also not keen on dropping Garmin money… so I’m tip toeing that line between admitting defeat and returning what I thought was an amazing deal or getting it figured out and enjoying a lot of features at a low price.
Won’t take long to learn it but will take some time to master it so you might lose a second or two on you usual interval times.
My revelation came when I realized you don’t flip and rotate to end up pushing off with your face point toward the bottom of the pool. You push off on your back with your face pointing to the ceiling and that makes it so much easier. I was trying to flip and rotate all at the same time and it was a mess.
You made me spit my coffee all over the keyboard with that one. I’ve been swimming since I was 7, so about 51 years, in high school, college, the Navy, and Masters, and I still screw them up once in a while, usually when I’m “taking it easy” for whatever reason. I’m not alone in that respect with the Master’s group. We all blow it once in a while, usually at the most unexpected time.
As for learning them, done even marginally correct will get you several seconds per 100, even on the very best open turn.
I think I was 53/54 when I decided I would learn this. At that age, it wasn’t an easy thing to learn. I started by devoting 10 mins at the end of every practice to flip turns. Eventually, I started putting them into the warm-up and practicing some more at the end. After a few months of that, I started trying them during the main set(s). But flip-turning in the middle of a hard set when I wanted an extra breathe on an open turn was the hardest. It took another several months to master. I’m glad I did it.
The first half of my first year on swim team (pre-meets), I would never flip in the deep end, only in the shallow. Then, I would dive down and basically do a handspring off the bottom of the pool and spring my legs into the wall. Looking back, that was probably more complicated than the actual flip. I stopped doing it when the guys started mocking.
Note: Learning how to flip is not that complicated. Mastering the flip to the point where not flipping feels wrong might take more time. For me, that time was about 6 years of competitive swimming. So be a patient padawan. Once it fully clicks, it’s really pretty nice.
Def learn the flip turn. It makes the swim a lot more like unbroken swimming for the typical AGer, which is better for training (and faster). I’d say for the typical AGer like me, it’s a noticeable improvement in swim training quality ; it’s not just some useless trick that looks cool.
The advice above was all great; two additional very helpful tips that really clinched it for me -
Accelerate into the wall to flip turn. This feels very counterintuitive for folks learning to flip turn, as you’ll be afraid to crash into the wall or lose control due to the added speed. Trust me - I’ve never once crashed my head into the wall by doing this, and I’m no expert. The added speed coming into the wall dramatically eases the difficulty of the flip. I wasted a few weeks before I saw this tip somewhere, as I was slowing down to prepare for the flip turn, which makes the flip really clumsy and hard.
You may have to swim a bit less hard during the rest of the length compared to your open turn pace. Your net pace will still end up faster with the flip turn, and it’ll feel just as hard over the long run since the O2 debt will get you. But you won’t be able to hammer the length, then spend 1 second recovering at the wall as you might be doing on an open turn. I revisited this recently when I cranked my neck and couldn’t flip turn as a result - I noticed I was feeling punchier and less O2 deprived on the swim lengths but my overall time was still slower due to the wasted 1sec per wall touch.
Admission.
I was a competitive swimmer, but not in Freestyle. So never developed a good long flip turn.
So I say, that (except for a pool race), there is little value in a flip turn in open water competition.
While many will tell you it will gain you seconds in 100m times, the reality is stil the samel, there’s no flip turns in open water.
Most people I have practiced with in club swimming end up doing short turns when they do flip, which ends up being just as slow as an open turn.
Unless you can also change sides of a lane at will, as any club swimmer can, your flip turn will be a nuisance in a shared lane.
If your 100’m are not under 1:30 doing or not doing a flip isn’t your problem.
My Garmin is quite happy catching the turn. But I cheat and set mine to walk, so that it shows HR.
Because if you are doing a set workout, you already know how far you went.
But if you must learn, take this into account. Most people who learn to flip late in life, do really short turns because they have bad breath control.
It’s the discipline to go into oxygen debt and come off the wall long with a dolphin kick that makes it work.
If you aren’t beyond the foul rope when you surface, it was a waste if time.
Good luck.
You neglect the reality that for most mopish age groupers who are the ones who are usually debating to learn flip turns or not, they tend to over rest at the walls during their open turns when sets get hard. Even a 0.5 sec delay at each wall touch adds up to 2 sec per 100 of added rest, which is a big deal when you are at your limits.
Flip turns force you to not over rest at the walls when it gets hard. This is the most important thing for the typical age grouper who is used to open turns.
If you’re a ffop swimmer in triathlon, you don’t need to learn to flip! For everyone else, I’d say it’s a required skill.
