Who wears one, if so, do you like it and where can I get one? My fitter suggested it among others. Anyway, thoughts?
Try this website:
I’m guessing that R&A cycles www.racycles.com probably has them as well.
I’ve had one for a couple of weeks now and it’s actually probably the nicest aero helmet I’ve owned. I’ve worn the rocket (nice but heavy…), Spiuk (very nice, light, easy on the ears but the retention wasn’t all that hot and really concentrates pressure on your forehead leading to the dreaded “forehead dent”), Giro (also very very nice although a bit claustrophobic on the ears) and then demo’d a Rudy.
The Bullet feels like the lightest of the bunch by a good bit although I haven’t actually compared weights. It has a killer retention system which snugs very evenly and fits a pretty wide range of head sizes for a given size. The tail looks higher and shorter than others but weirdly when you compare them it’s the same length as a Giro and fully touches my back when I’m aero. The only issue is the little vents in the earpieces are LOUD. Tape them over and you’re good to go.
I find it very comofortable. pretty light
You chicken! You made that backround just to post a photo on ST! I still say your carpet is dirty!
Has anybody tried the Lazer Tardiz (love the name! definitely aimed at the tri crowd)
Has anyone tried their road helmets, like the Helium. How does it compare to the Giro Atmos? how is the retention system?
Thanks for the responses. I saw that it had an option in black too. I’ll check about the black one as I prefer to the gray one.
Just about every retailer I called was out of the Lazer Bullet, stating that the Tardiz was on it’s way. I found someone that sells the Limar Speed Demon in that graphite color. I ordered it. Thanks!
I believe I am one of the only (if not the only) person that actually has a Tardiz in NA.
The retention system is like Lazer’s other helmets. twist knob on top tightens the retention straps around your head. Very comfortable and will come in 2 sizes S/M and L/XLG
side by side by side with the Lazer Bullet and a non CPCS Giro Advantage (which is smaller than the CPCS Advantage II)
