Looking at some lactate curves got me thinking.
At which power/speed interval (percent of Vo2max) does the lactate threshold occur?
I guess this is partly genetic and also trainable?
How much can one train this?
Is it different in bike and run?
To increase the lactate threshold one can both right shift the whole curse (increase vo2max) or more the lactate threshold
to an higher percent of vo2max?
Can someone confirm or clarify ?
I have measured a lactate threshold everything between 80% and 90% of vo2 max. I’d say 80-85% is quite typical for a trained endurance athlete. The higher, the better. Maybe I was able to push mine to 90 simply because I wasn’t able to increase my Vo2 max more, but I think a value over 90% is exceptional. Vo2 max is possible to increase only to a certain degree and doesn’t tell much about a triathletes actual performance level, while the lactate threshold essentially is everything. I’m not sure what the relative value would be for an untrained person, but it is possible to push lactate threshold further simply by training at a pace near threshold effort. Raising vo2 max would also push further the lactate threshold, but as I said it is only possible to increase vo2 max by some 10-20%.
That depends not only on the individual, but on the exact criteria used to identify/define lactate threshold. For endurance trained athletes, though, lactate threshold (no matter how defined) will generally fall somewhere between 70% and 90% of VO2max.
Yes.
As a percentage of VO2max? On average, about 10%, sometimes more.
Unless you’re a trained cyclist being tested during uphill running, then yes.
JerryC, enjoyed the information summarized via this link. Very clear about cost-benefit for training plan design relevant to aerobic/anaerobic balance. Thanks for sharing this here! Beth Leasure-Hudson
