Kona Webcast Available for Download
I am in the process of uploading the ironmanlive Webcast for Slowtwitchers to download and watch. Format is .asf (streaming video as transmitted). I have opened and viewed in both RealPlayer and Windows Media Player.
File size is large but manageable. It’s split into four files, the first **three **of which are available here:
http://s23.yousendit.com/d.aspx?id=3B244KACITV04084QAJQ1XE57Z
and here:
http://s24.yousendit.com/d.aspx?id=2Y4K0IF3BS5P605K1A7HJEV5G
and here:
http://s33.yousendit.com/d.aspx?id=1XAO51KP4GVWA2HHJPSZ37VZ11
The final installment, Part Four, is here:
http://s35.yousendit.com/d.aspx?id=34PTUTUJJSP4R0534D4E4ITEQW
The link will remain active for one week, after which time interested parties will have to acquire it through another upload or other means like P2P sharing.
I’ll continue posting links as uplods are completed.
Enjoy!
Unfortunately, the link you have clicked is not available.
Your transfer cannot be completed. The file has most likely exceeded its allotted bandwidth or has been removed by the original sender or a recipient.
That was quick! :slight_smile:
It worked for me!
Part Two has been posted:
Part Two is working. I have no idea why Part One isn’t. I did not remove it. Maybe there were too many requests.
OK, suggestions for a different similar type service, please.
Thanks, got the 2nd one but still can’t access 1st one??
As Tom D. likes to say, fiddlesticks. This is the email they send to the recipient when the upload is completed, so apparently they set a limit on the number of downloads:
Hello from YouSendIt,You’ve got a file called “kona2005-p1.ASF” (304988 KB) waiting for download.Message:ironmanlive Kona broadcast, Part OneYou can click on the following link to retrieve your file. The link will expire in 7 days and will be available for a limited number of downloads.Regular link (for all web browsers):http://s23.yousendit.com/d.aspx?id=3B244KACITV04084QAJQ1XE57Z
Redy for Part 3 :slight_smile: This is great! They’ll definitely be useful this winter on the trainer!
There is usually a download limit on yousendit to stop leeching. The folks that download the file should pay it forward and re-up the file and post the new link. It will last longer that way and it’s free. Try rapidshare next time because the links don’t die. Once I split the one that I have I can upload. What did you use?
Well it worked for me earlier but no I get the unavailable message. : (
Part III + IV? Thanks, awesome!
I only managed to get part 1 so far… I want more :slight_smile:
I only got part II, so how would you record a live webcast?
I’ve got some server space and can repost once I get a copy, how large are the files??
Part 1 is 297 MB… the others are probably the same.
Part I- 318MB
Is there any way to put this on a bittorrent tracker, that would be the best option. That way, we all share the bandwidth needed to get the files out. It’s the ideal medium for this size of file.
J.
I’m getting the same message… any one else able to download it?
I’ve got most of my issue fingered out to.
Hook up to E-mule server 195.245.244.243
Search for Kona 2005, as stated before 40 chunks roughly 40-60MB.
~Matt
I put it on E-mule look at my other post. Right now I’ve got my bandwidth wide open. My brother hooked up and is downloading at roughy 40KBs. Still slow coompared to a direct download but I have 40 chunks. If each person picks a chunk it can be out there pretty quick and people can be loading from multiple sources.
~Matt
~Matt
And for those of us who have no idea what the second two sentences mean…
