Trying to nail down a set of rims for a new bike and I have narrowed the list two these two rims
Building on a Powertap GS hub front (24h) and a simple 20 hole front hub (probably a superlight hun from BHS)
The 279 is cheaper, a little heavier, 1mm narrower.
The Xr31 is 3mm deeper, a little lighter, 1mm wider, and has an option of an offset rear rim (3.0mm) but is nearly 60% more expensive.
I would go with them, but is appears they want to charge me over $100cdn to ship the rims. Which is ridiculous, costs the same price as a rim, and is twice the shipping charge of alternative retailers.
$100? PM me your address if you don’t mind. I’d like to look into that.
I also noticed the Flow 30’s are nearly 100g heavier than the Kinlin Xr31, so I would be giving up 200g. Are the flows that much more arrow for the weight penalty?
I couldn’t tell you, I’ve never seem data for the XR-31, but it’s just a basic V-shaped 31mm rim with straight brake tracks so in theory it’s somewhat slower than the Flo. I use them for general riding and training and race on deeper wheels so I’m less concerned with the aerodynamics on them.
I suspect the 570g listed for the Flo weight is wrong. First, it’s hard to understand where all the extra material would be compared with the XR-31 (which is already a pretty beefy rim). Second, that implies that the front hub and spokes are 155g all together, which seems way too light. I’d bet the rim actually weighs 470g and that webpage has a typo.
With sapim Cx-ray spokes and nipples the hub would be sub 50G. That is not very likely.
Very happy with them so far, the fit and finish is nice. When measuring the ERD they appear to be consistently round, and they sit very flat on my granite table, so I figure they should build up easy with even spoke tension.
The weight was interesting. The 20 hole front weighed in at 578g, the 2 hole rear was a feather weight (LOL) at 530g. Left me wishing I had two rims at the 530 weight so my wheel set would have been a hair under 1700g.
Anyway. Now I have to order the spokes and a front hub to build the set up with.
Thanks to the guys at Flo for helping with figuring out the shipping to Canada, and everyone here who advised these rims.
