Kestrel TT Sizing Help
Hey all, due to sponsorship reasons I am going to be purchasing a 2010 kestrel, more than likely the air foil pro sl or the 4000 shimano. I’ve read through a ton of forums and measurement posts, but haven’t found too much fitting my needs. I’m trying to find which size will fit me best
I’ve been riding a Medium 2008 QR Caliente, and I think it is on the small side for me. I’m not too sure if i’m long/short legged/torso, always just figured I was average with long arms, but here are my measurements per Competitive Cyclist (do not have fist measurements). I try to ride with flat back due to lb disc issues and therefore ride pretty steep (but not a ton of drop). I know not to make final decsions based on comments here, I just wanted some feedback so I know what I’m getting into. Thanks!
Measurements
Inseam: 32.75
Trunk: 25.5
Forearm: 13.5
Arm: 26.5
Thigh: 22.5
Lower Leg: 21.75
Sternal Notch: 57.75
Total Body Height: 71
The Aero Fit
Top Tube Range: 55.4 - 57.4
Stem Length Range: 8.0 - 10.0
Saddle-Bottom Bracket Position: 74.9
Saddle-Pedal Position: 92.1
Saddle-Ground Position: 99.9
Cranklength: 175.0
Aero Bar Size: M
Saddle-Aero Bar Pad Drop Minimal: 5.6
Saddle-Aero Bar Pad Drop Moderate: 10.8
Saddle-Aero Bar Pad Drop Intense: 13.1
Saddle-Aero Bar Pad Drop Maximal: 16.8
Pad-Ground Position Minimal: 94.3
Pad-Ground Position Moderate: 89.1
Pad-Ground Position Intense: 86.8
Pad-Ground Position Maximal: 83.1
your a little taller than me but not by much and I also ride a Med QR and would ride a 52 Airfoil but unforunately for you they are meant to be ridden in a pretty steep position thats what the geometry is made for. Maybe look at their talon with you could get a litte more comfy position for your back.
I’ll be back in the office on Monday. Feel free to call me.
