Jan Heine - better bike frames and "planing"
https://janheine.wordpress.com/2018/01/28/myth-4-stiffer-frames-are-faster/
Found this while looking for other things and didn’t recall seeing a discussion of this on ST. Tried searching ST… Much of what Jan Heine writes on other bike topics I also see on ST. He sounds knowledgeable and I’m finding him elsewhere in cycling circles.
He suggests that frames do/don’t flex back and extend the benefit of a pedal stroke. Proper flex back helps the rider go faster/easier.
“Planing” almost sounds like a situation where if you push on something that springs back then the push back forward makes cycling 12% easier.
Some caveats:
The amount of the flex back desired in a frame is dependent on the rider.
Seems like a rider can get in tune with the bike if “it’s” going to happen. It might not happen on a trial ride.
Some builders - Specialized, others - say they don’t make every part of their frames just stiff or light.
What do you think of a bike frame “planing”? Do you have such a bike?
I think that that what Heine calls “planing” is very poorly-understood, but that there’s something to it.
As far as Heine’s own studies on the matter go, he did a double-blind frame flex experiment. With only 3 participants, the results are not generalizable to the cycling population, but there was clearly something happening.
Beyond Heine’s testing, I’m not aware of any published data on the matter of how frame flex affects pedaling. But, Cannondale’s Damon Rinard indicated that he saw something similar.
I do have a bike that doesn’t pedal very well for me. It’s a traditional road touring frame, stiffened up quite a bit in the upper part of the double-diamond to be stable with rear loads. And for what it’s worth, that’s pretty much exactly what Heine recommends against for “planing.”
https://i.imgur.com/6ukhoPT.jpg
At high intensities, I just can’t seem to get good performance from my legs. My quads will be burning well before my lungs are straining very hard.
I think my other bikes mostly pedal pretty well for me. They don’t all pedal the same, but they pedal well.
Interesting article, thanks for posting. I don’t know about the claims in the article, but I have a first gen Cervelo S3 road bike that is definitely too stiff for me. Beautiful bike, but not much of a joy to ride unless the road surface is glass. My experience with that bike has always made me snicker a bit at manufacturers tripping over themselves to claim their bike is STIFFER!!
I’m guessing that “planing” describes that sensation of your pedal rate being in synch with the flex of the frame, rather than at a different frequency. Could be very wrong though.
Personal thoughts: Stiffness or flex isn’t the issue, it’s hysteresis, i.e. absorption of the energy put in and released by flexing, rather than it being efficiently returned to the output.
One more thing though, from that series, I wish every bike user and light manufacturer would read this:
https://janheine.wordpress.com/2018/09/20/myth-14-more-lumens-make-a-better-light/
Heine has better skills at marketing than in running careful experiments.
I said to Phil White that same comment; but that if he put the rear stays of the R series onto the S Series it would be a better ride.
The original design was a monostay and quite a jackhammer to ride. I bought an R3 despite really wanting the ‘aero’ road bike.
Voila, my dream came true and now I have the best of both worlds in my 2014 S3 - aero for my slow ass but comfort for my fat ass
ouch.
tru dat
“On the stiffer bikes, our legs hurt, but we never reached our maximum heart rate. On the more flexible bikes, our legs didn’t hurt, but we were completely out of breath when we reached the top after putting out significantly more power on the climb.”
Legs hurt but never reached max HR?! Did they try a smaller gear? I suspect the flexy frame was the one they were accustomed to.
The flexible frame will move away from the force, which I guess means a lower peak force but longer duration for the same power output. Some people like oval rings for modifying the force-speed curve, and that seems like a better approach. Frame flex is going to involve some hysteresis losses, and absolutely sucks when going down hill.
I have the same bike, 09/10 S3, which is absolutely a keeper for me, she’s always whispering “you know you can shift up another gear”. We have zero glasslike roads here, but for me, this bike glides and flies.
Thereby reinforcing the possibility that it’s a very personal thing as to what might work for you
On another page/ he mentions being in the right gear can help in being tune with the rebound of the bike. I think that or there was another page where he mentioned how inefficient cogs 11-13 are resistance wise - that I definitely feel. I seldom use 11-13 and when I do the chain and teeth are so close together that I can feel the individual chain links. He said that larger rollers on the derailleur helps with that.
Elsewhere he mentions the oval chain wheels and how trail impacts downhill.
It’s a lot to take in, if there is something to a bike frame rebounding with the pedal stroke and “elongating” each pedal stroke if you are in the right gear.
I know. The experiment won’t convince many. His years on the bike has me wondering, along with bike manufacturers claiming that that their bikes are better tuned, AND THIS experiment/illustration.
https://www.globalcyclingnetwork.com/video/are-you-faster-on-a-stiffer-bike
This makes sense physics-wise but i’m curious as to the best way to act on it. Do you just have to try different bikes and get lucky? I’m assuming you could talk to the frame builder if you were going to get a custom frame, and this might be something they have a view on.
But i think my Speedvagen CX bike is still a few years off unfortunately :smiley:
BQ’s experiments are fairly coarse and don’t do a great job isolating factors. And Heine’s opinions obviously bleed through into the analysis.
But BQ’s big-picture style of experiment can be useful at identifying things worth looking into. I feel like that can be relevant in a place like the cycling industry, where traditions are so strongly propped up by momentum.
It’s not terribly useful if you’re trying to optimize to the last watt. But they’ve been pretty early to the party on some things, i.e. their data indicated that tire inflation was relevant to suspension performance on road bikes all the way back in 2006.
I’ve tried consciously pushing myself toward higher self-selected cadence on my Campeur, and it just feels like the legs are having a harder time really connecting with the drivetrain. Even at cadences which don’t feel bad on my other bikes.
I don’t see that the flexing frame is providing any “benefit” that oval rings wouldn’t do better.
If your legs are “sore” on a climb but you aren’t breathing hard, then isn’t a lower gear an obvious choice? IME my breathing is always maxed out, so the situation seems contrived.
Heine spoke about suspension losses and was an early advocate of fat tires on road bikes, but that doesn’t make him a genius about everything… :wink:
You also live at 7,300’ elevation.
Some caveats:
This whole flex thing was solved many years ago. That’s why we’re all still riding Teledyne Titans and Vitus 979s.
:wink: True, but it was also the case when I lived on Kauai. If my breathing isn’t maxed out then I’m not going as hard as I could. Is this not normal?
Your scenario is not what Heine describes, he describes “sore” legs while not breathing hard. This is a sensation that I have experienced, more often at lower altitudes. Typically it’s a result of too big a gear (as you point out), underfueling, soreness from a prior workout, inadequate warmup, or (in fewer cases) extreme fatigue or lack of sleep. Or any combination of these things.
In other words, many people’s legs hurt when they’re nowhere near going as hard as they could. A different frame or chainrings is not the primary solution to the factors that cause this.
Put me in the category of this is nonsense. If the effect does occur, it is negated by the energy put into flexing the frame - even if you get 100% of the energy out of the “push back” which you would not.
I don’t believe that stiffness is as important as many people have believed but I certainly don’t believe flexibility in a frame magically gives you 12% more power. If it did, we would routinely see 30 watt differences between pedal power meters and hub meters and consider it normal because it means we have to be losing that power into the stiff frame compared to the flexible frame. (And we all ride too-stiff frames compared to what he was testing). Conservation of energy demands that be true. Extra energy can’t just come from nowhere. Lost energy has to go somewhere.
Your conjecture isn’t correct. Heine isn’t claiming the 12% is lost between the pedal and wheel on a stiff bike, but that his legs feel better on the flexy frame, allowing him to produce more power. It’s a purely physiological effect.
