If you say you’ve got something, you need to be someone on here with a decent post history. I won’t respond if you’ve got like 25 posts and sound like a chat bot.
With that out of the way…I think I want to change it up frame size so I can run a lot of stack spacers to get the elbows higher away from the base bar. Fit wise I can already accomplish what I want, but would like to try this.
I don’t really need all the stuff, pretty much just the actual frame (not even the fork, or seat post, or brakes). But would take it if it’s the triathlon fork or base bar, as those are faster.
This would be the newer ones that are the final rim brake generation they make.
So, 2016+ rim brake Trinity size M frame.
