ISM Adamo users
I’ve become a recent convert to this saddle. After having issues with my old saddle a friend of mine gave me his old ism Adamo race. So a few questions what are you guys using or what fits this saddle for hydration purposes and does the old ISM Adamo race still exist today in a different version or have there been some changes I understand it’s one of the PN Saddles but I don’t see anything that mentions a race version in any of the charts.
The old Racing saddle is now the PS line (performance short). The PN line is the narrow saddles or what the old Attack was.
I’ve used a few different models of ISM saddles over the years, even on the mtb, and the PN3.0 is my new favorite. But, like shoes, this is a personal thing.
Regarding hydration, I’ve always used a single bottle cage, zip tied to the seat rails. I’ve used a specialized cage and speedfil cage with good results. The speedfil cage is easier to mount because it has special slots for zip tie mounting, but doesn’t hold as snug as some other cages.
You’ll probably have to contact ISM about version updates over the years. I have the Road and I’ve not found an inexpensive solution for a rear cage. Reason being, the saddle sits so far back on the rails that it interferes with the typical rail clamps. I gave up trying and just opted for a BTA setup.
This has the hanger on back of the seat 4 the rails and transition so if I put a cage back there hanging my bike will have to go with the Aero bars. I was one thing I really liked about the tritone was the hanger was on the front of the seat
So the new version of the Race/TT is the PS1.0. I use a 2 bottle BTS holder, which makes it so I cannot use the hanger. The holder I have does not exist anymore it was made by trek, but XLabs has a couple nice ones.
I have found most of the time I can hang the bike by the nose instead of the rear hook, although that always depends on how tall the set up the racks.
I have been using that saddle for 6 plus years now. For long course I have used the x lab wing mounted behind the seat. It is a tight fit and will come loose if the road is washboard but has worked for me.
Thanks. Turbo wing?
No, it was sold as carbon wing.
Are you saying the Carbon Wing is coming loose? If it is let me know if I can help - it definitely shouldn’t move after you install it even if you have rough road.
It does, I put it on and snug it up to the saddle and by the end of the bike leg it has dropped a bit and is loose. It is a tight fit with that saddle and not an easy install but I like to use the wing as my flat kit storage.
Shoot me an email - I think it could be the hardware that is causing the issue.
My TT bike is a Spec Shiv
I used for 4 years the Adamo TimeTrial or Racing with Carbon Wing (IM) or “old” Delta 425 (70.3)
But now i am using the PN30 and i can’t use my old Delta (1 bottle)
The distance between rails is different
Looking saddle compatibility in XLAB website i can not find any carrier for new Adamo PN 30.
:frowning:
:frowning:
I had the PN3.0 and now have the 3.1 which is the same but with more cushion. Carbon wing works perfectly on both, with the carrier nice and horizontal. With the Road I had to angle it downward a bit to fit
Not exactly a reply, just looking for someone who can help.
I’ve been using the Prologue model for a while now, 4 or 5 years can’t remember. Never had issues until I changed from a Felt s22 2012 to a Felt IA10. I was very comfortable in the past, but now, after an hour my butt hurts. At 1:30 it’s really bad and anything over that is pure pain up to my waist.
Any recommendation on what saddle to substitute it? or at least diminish the pain?
:frowning:
Here’s a pic of my carbon wing:
https://i.imgur.com/c1crGKx.jpg
https://i.imgur.com/o9ECkAj.jpg
+1. Zipties
I ride an ISM Adamo Race with an X-Lab Carbon Wing. Fit is fine. I agree you really have to crank the hardware down or it does rattle loose.
I just changed to the pn 3.0
Way better fit for me.
Does the Cervelo seat post have the through axle mechanism where you can insert the likes of the tririg bottle carriers? My Scott does and it is great and I though some Cervlos had the same mechanism.
