Ultra Cavitation is a safe, nonsurgical procedure without anesthesia, it is non-invasive ,no cutting, no scars and no downtime should be experienced after the treatment. There is no report of side effects for these treatments.
Ultrasonic cavitation is one of the oldest techniques used for dissolving the fat cells. It actually melts the fat which as a liquid goes out of the body through the kidneys in a natural way. Due to specific ultrasound parameters of energy levels ensure selective damage to fat cells only and do not interfere with any other organs. No surgery is required no anastatic is needed and more important there is no pain. Because of its accuracy they can get rid of your love handles,sagging under arms fleshy thighs and sagging bottoms. However some people may experience transient redness, excessive thirst, and nausea immediately after the treatment which always resolves by drinking water. They are all short-term effects that will disappear shortly.
Ultrasonic cavitation has become a broad used procedure worldwide. There are lots of brands that apparently offer the same but, these are some thinks you should look to get a better result.
Ultrasound frequency between 35-42 KHz, lower frequencies as 30 KHz could go deeper and damage your abdominal muscle wall or irritation to internal organs.
Cavitation will only help to break down cellular wall without killing it but still you need something to heat up the fat in order to help it get out of the cell then to the lymph circulation to be used on the muscles and then disposed through the liver and kidneys. That being said if you get a therapy that is Cavitation and simultaneous monopolar radiofrequency you’ll get that effect plus skin lifting. Some equipments has it separate and although it works, it won’t be the same way. Try to find info about Ultrasonic cavitation slimming equipment at toplipolaser.com.
Cavitation will be best performed under high hydration conditions, avoid taking any caffeine or diuretics 2 days before therapy. After therapy you can take caffeine as many as you want, this will help to improve your metabolism and increase urine output – lipid metabolites release out of your body.
Now of course it is not cheap. In fact it is on a par with plastic surgery in cost but the result is far superior and it lasts once it is done you do not have to repeat the procedure. They can turn a size 16 into a 12 so you expect to pay for something that can do that. Keep on a good diet, if you keep on eating bad stuff you’ll gain the fat back.
