Is swim TSS on TP inflated?
So I did a 4400m swim today and TP Gabe me a TSS of 98. A few days ago it gave me a 65TSS for a 3000m swim that included lots of drills. My threshold is set at 1:30/100y which may be a couple seconds too high depending on which test I do.
I feel that these swim tss are too high and play a havoc on my PMC. So the 4400 swim and an easy 8 mile run combine to 175 TSS. I feel that I had a decent day but not 175TSS of a good day.
So am I underestimating the swim stress or is TP overvaluing it?
TP seems to struggle with swim TSS. After all, assume you just did 3,000m in purely kick drills. Your “swim speed” is going to be slow compared to your threshold swim speed but you’re probably going to be exhausted. TP will give you a low TSS thanks to the speed comparison…
So how is one to manage that on TP?
Ignore the swim? Apply a TSS manually based on feel?
Your bigger issue is combining the two together. Although the PMC is a good feature, it’s always going to have that flaw.
It is a 175 day. But a 175 run day, 175 run/swim day, 175 bike day, 175 run/bike day are all really different stressors and combining the individual workouts will only give you a very rough estimate of training load.
I just roll with it. I let the workouts upload so that I have a record of what I did and use whatever TSS it assigns. In the end, the form and fitness functions are just estimates and have to be informed by the way you actually perceive your effort and fitness levels to be. Ideally, you can look at the training log of activities and see the progression of fitness based on performance in workouts but relying on the output fitness number alone can’t be enough. There is an inherent unknown in any system.
That being said, on your original example day, a 4,400m swim and an easy 8-mile run may well rack up 175 TSS depending on your thresholds. Would that leave you exhausted? The swim is likely adding fatigue to your upper body more than your legs and the run is hitting your legs while ignoring the arms and shoulders that the swim worked. So you may not be expected to be as exhausted as 175 TSS of all running. For that matter, once I have my fitness in a reasonable range, 175 TSS in a day isn’t a bank breaker.
I just go with 1 TSS per minute…so 60 mins= 60 TSS. Close enough for me.
I think the don is off from the tkn and owwha, that messes with the tthe, therefore the fuc values is differentiated from the kyou ones, all displacing ar values, and etal, from the king. About sums it up
That’s still about 2.5 hours of working out though, right? 175 seems a little high, but reasonable to me for swim/run. (works out to ~.83IF)
Yeah I find this is a more accurate reflector of training effect. and be sure to use actual swimming time NOT the time you were in the pool, i.e exclude the rest times
No, that includes rest time. So if I have a 60 min training session including rest between intervals, I log 60 TSS. Should it be 50 instead of 60? Maybe, but close enough.
Well each to their own but I find for an hour of swimming that my tss will feel more like 45 which is more like the actual time swimming. If I am doing more aerobic I might lower it a bit and if I am doing closer to threshold then I might increase it but I never log the entire time I am in the pool…
disclaimer: I am shit
About 75 min run and an A session of T26. So close to 3 hours. I am skeptical because I actually feel pretty good. If I had done an equivalent bike run workout of 175TSS or a long bike or long run workout of 175TSS, I would be quite a bit more tired.
Is that even English?
Sounds like you’re just getting pretty fit!
I think the don is off from the tkn and owwha, that messes with the tthe, therefore the fuc values is differentiated from the kyou ones, all displacing ar values, and etal, from the* king*. About sums it up
Thats what I was wondering about the OP! What the hell is he talking about, my Timex ironman watch($24.95) has non of those acronyms
See if you can now understand it, I highlighted the relevant parts…(-;
HAAHAHAHAHHA… you have too much time on your hands. But thank you for the laugh.
Lol. I should have done some code breaking.
The recommendations to use 1TSS per minute are probably best. The figures are inflated because there is no rest included in the calculation. If you did a continuous swim with no rest (like an OWS) the TSS would be closer to accurate.
That said, I don’t bother including swim in my PMC. I don’t feel like it affects my run/bike training very much, and when I swim I’m swimming regularly, so there is not really a lot of ebb and flow to keep track of.
T The figures are inflated because there is no rest included in the calculation. If you did a continuous swim with no rest (like an OWS) the TSS would be closer to accurate.
Yeah, the TP TSS calculation for swim gives no consideration to the rest time, only the moving time. That really doesn’t work if you’re doing short-distance intervals that have a high anaerobic component.
I found the TP TSS formula, and tweaked it. I figure the TSS just as they prescribe, then I re-figure it with the pace including all the rest time, which results in a much lower number if you’re doing any sort of interval training. I blend the two; 3-parts moving-time based TSS, and 2 parts rest-included TSS. For simplicity’s sake, you could just average the two and it wouldn’t be much different.
Think what’s most important is making sure you’re being consistent about how you apply whatever smoothing you do to the TSS. Shouldn’t be anything dramatic, but I can see room for a little upward or downward based on RPE
