Yep. Totally in line with what I have noticed. Also great to get some validation about not really being concerned.
I never had cadence until I got a PM about a year ago and was making observations about trends, but not changing my behavior because of them.
But if I’m in an olympic and spinning at 80 RPM I may want to pick it up. Likewise if I see 95 in an IM, could be a sign to dial it back.
95 RPM in an Ironman would be a disaster (probably best way to assure a walk on the run course). Basically what you are doing is expending a ton of extra energy moving the huge mass of your legs around in say 15 extra circles per minute to put exactly the same watts to the pavement as the guy riding at 80 RPM. There is a reason why RAAM riders going at ultra low RPM ride that low…it is because their wattage is also ultra low.
To add another point of reference for direct comparison between two races of equivalent difficulty but one being a full, the other being a half IM
IMLP: 81 RPM 185W, 5:36, elevation gain 1900m, (this was my ride time and did not include a flat change)70.3 Tremblant: 85 RPM, 218W, 2:33, elevation 963m.
In both races I also performed to my current run fitness (3:51 at IMLP, 1:38 at Tremblant 70.3). I am pretty sure if I had data for an Olympic tri, the average cadence would end up being 90 RPM.
Looking at my Garmin connect data, I have one other point of comparison…Epicman Tremblant: 78 RPM, 165W, 6:30, 2250m elevation, 190K
So as you can see, when my watts dropped by another 20W and the duration went up to 6.5 hours, my cadence went down even more. And none of this was planned…it is just what it ended up being.
There are three solid data points I can share all done on the same bike, same fitness (more or less), with similar elevation profile.
Dev
