Hi,
Older rider here. I’m looking into getting back into cycling. Right now my Cervelo R5 has just 10 speed dura ace components.
I’m looking for some opinions on if it’s worth it to change over to a single up front. Climbing gears are a high priority. I currently have a 34 tooth on my rear cassette.
I’m not a powerful rider so having truly aggressive gears of high speeds isn’t necessary. I’m doing good if I ride at 22-25 mph throughout bike rides when in condition.
I assume this will be kind of costly changing over.
You could just convert to a single speed with a bit of hacking - guessing this is an older bike, with the kit you mention, and it’s set up to work optimally with a 2 Chainring set up on the front.
Tom,
Thanks for responding. I’m not a gear head. I am an average rider. I mentioned getting back on the bike and being a rider of 59. I’m not focused on top end speed. I am wanting why bike to be best geared for hills.
That being said will moving to a single sprocket with a huge cassette on the back going to be worth it.
Thank you
As everyone said above, there’s no good reason to switch to 1x in the hills. It is absolutely a compromise. If your ftp is over ~3 watts/kg… It can work, though…but, it’s still a compromise.
I just found your description of your ride paces (22 - 25mph) to be more consistent with a stronger than average rider…not a weaker one.
