I’d say there’s an easier way to see it. You can get a Dash focused on TT/TRI or get a Dash focused on road/TT. The confusing bit is whether you need to be UCI compliant or not. That’s the only reason you get to see more than one even though they are basically the same saddle with the added part on the back to account For UCI rules.
So in a nutshell: if you’re planning to use it on your TT/Triathlon get either the tri, stage or the tt depending on whether you need to comply with UCI. I didn’t since I don’t do UCI races, hence I chose the tri. But in reality, any of the other two would’ve feel the exact same because they are basically the same design, only extended for UCI rules.
Now, if you’re looking for a hybrid solution, that will allow you to sit upright, but at the same time, get aero, get the Strike. It looks and feels more like a Specialized Power Arc, per se. I would have to say, either of the tri/tt/stage will feel more comfortable in the aero, for longer periods.
See? I know it’s hard, that’s why I had to get both. I use one on my race bike to race or ride outdoors, and the other one for the indoor, when my aero is limited by my fragile mind.
THIS was the post I was hoping to find, thank you so much man! These saddles are quite confusing, and since they’re so expensive comparatively, I wanted to make sure I’m getting the right one and don’t regret it.
Even when I’m on a hilly course, over the distance of 112 miles, I’m in the aero position FAR more than I am sitting upright. Knowing that those 3 are exactly the same fundamental shape with UCI compliance added into them (which I don’t care about), then the Tri would be the saddle for me it seems. I don’t sit upright enough to warrant the need for the Strike.
Is your Tri a standard or narrow width? I would be leaning more towards narrow due to the problems I was having mentioned in the OP
