Ironman Death March
I need help! I have done 3 IMs and several 1/2 IMs. On each of the IMs my run became nothing short of a death march. This also happened during one of my 1/2s. I suspect it is my nutrition and my specific body physiology. I complete the swim and bike portions in fairly good time (I start my run between 6’30" and 7’00"), but I fall apart on the run. It does not feel like a lack of fitness, but rather a lack of energy (a total bonk).
My usual race day scenario is as follows: Eat a good breakfast about 3 hrs. prior to race and drink electrolyte (Gatorade, GPush, Cytomax, etc.) up until race time. Just prior to starting the swim I take a Clif Shot. Once on the bike, I try to drink electrolyte every 15"-30", a Clif Shot every hour, and either energy bars or a sandwich (I have tried both turkey and PB&J) between 60-70 miles. In addtion, I will usually eat a couple of bananas from the aid stations.
Invariably, around mile 80, I start to feel a little quesy and, combined with beginning to feel hot and tired, I simply can not eat any more(including gels) and any fluid I drink only makes me feel worse. When I get to the run, I think its too late. Although I drink plenty on the run (too much, I think because I spend so long walking past the aid stations), I am still not able to take in any gels or food.
I am not just feeling tired on the run, I am feeling totally wiped out. Believe me, I have been doing triathlons for 20 years and know the difference between just feeling tired during the run, and feeling wasted. This never happens in shorter distance races or in training. In training I will do plenty of 100+ mile rides, 20 mile runs, and long bricks. However, in training we will usually stop for 5 or 10 minutes to eat and drink during a long ride, and also prior to starting the run on a long brick. I hate to think that this is the only answer on race day.
Any thoughts on how to stay fueled for the ENTIRE bike and run? I wonder if my liver is somehow not allowing my body to access the glycogen stores in my liver once I have depleted my muscle glycogen after 3-4 hours of exertion.
I think I have a 10’30"-10’50" IM in me if I can solve this problem. I am doing IM LP in July, and really want to avoid the death march–it’s time to actually race. Thanks for your help.
Doug
Been there too. I my case its IM 2 me 1. But I think I have some solutions at least for me. There are a couple of really good articles on www.bryn.org in his tips section actually makes a lot of sense on nutrition and pacing.
I have been training on 500 cals an hr washed down with a fair amount of water (fuel is also liquid) and that seems to work at least for now. I also make sure I take salt tablets or put salt into my fuel. Maybe, if you have not done it already, try to figure out how many calories you can consume and how much water you need to a) digest and b) hydrate. Based on what you written sounds like you consume about 300 cals from bar and gel plus Gatorade (say 24 ounce bottle every hr = 120 cals or so) that makes 320 cals. Do you take addtional water to chase the gels and bars down? If not maybe you have a hydration problem and not a fueling problem.
The test is to weigh yourself before and after long rides using various fueling and hydration plans to see how much water you actually lose and not replenish. At IM NZ I lost 7lbs from the day before race to end of race! I did not drink enough to digest my fuel and went into a downwards spiral, was saved eating 15 cookies at the first three aid stations on the run, and drinking anything they had. It was a long walk/run.
Also try http://www.cruciblefitness.com/etips/IMNutrition.pdf
Hope this helps.
Sounds to me like you might be having too high concentration of carbs.
When you get above 6-8% concentration, you’re talking hypertonic. This means that the body will absorb drink more slowly than water, and you will end up dehydrated, and queasy.
Not sure what about concentration of brands you are using (I’m in UK), but sounds like you might need water to bring concentration back o 6-8% isotonic range. Fine to take higher concentration to replenish afterwards, but not during.
From Sports Coach
http://www.brianmac.demon.co.uk/drinks.htm
Sports Drinks
There are three types of Sports drink all of which contain various levels of fluid, electrolytes and carbohydrate.
Type Content
Isotonic Fluid, electrolytes and 6-8% carbohydrate
Hypotonic Fluids, electrolytes and a low level of carbohydrate
Hypertonic High level of carbohydrate
The osmolality of a fluid is a measure of the number of particles in a solution. In a drink these particles will comprise of carbohydrate, electrolytes, sweeteners and preservatives. In blood plasma the particles will comprise of sodium, proteins and glucose. Blood has an osmolality of 280-330mOsm/kg. Drinks with an osmolality of 270-330mOsm/kg are said to be in balance with the body’s fluid and are called Isotonic. Hypotonic fluids have fewer particles than blood and Hypertonic have more particles than blood.
Consuming fluids with a low osmolality, e.g. water, results in a fall in the blood plasma osmolality and reduces the drive to drink well before sufficient fluid has been consumed to replace losses.
Which is most suitable?
Isotonic - quickly replaces fluids lost by sweating and supplies a boost of carbohydrate. This drink is the choice for most athletes - middle and long distance running or team sports. Glucose is the body’s preferred source of energy therefore it may be appropriate to consume Isotonic drinks where the carbohydrate source is glucose in a concentration of 6% to 8% - e.g. High Five, SiS Go, Boots Isotonic, Lucozade Sport.
Hypotonic - quickly replaces fluids lost by sweating . Suitable for athletes who need fluid without the boost of carbohydrate - jockeys and gymnasts.
Hypertonic - used to supplement daily carbohydrate intake normally after exercise to top up muscle glycogen stores. In ultra distance events high levels of energy are required and Hypertonic drinks can be taken during exercise to meet the energy requirements
If used during exercise Hypertonic drinks need to be used in conjunction with Isotonic drinks to replace fluids.
Want to make your own?
Isotonic - 200ml of orange squash (concentrated orange), 1 litre of water and a pinch of salt (1g). Mix all the ingredients together and keep chilled
Hypotonic - 100ml of orange squash (concentrated orange), 1 litre of water and a pinch of salt (1g). Mix all the ingredients together and keep chilled.
Hypertonic - 400ml of orange squash (concentrated orange), 1 litre of water and a pinch of salt (1g). Mix all the ingredients together and keep chilled.
The Gatorade plus the cliff shot could very well be causing you some GI upset. For most of us its one or the other. There was a thread about week ago that debated the simple sugar vs the complex carb approach which included discussion about osmolarity gastric emptying. Worth the search and the read.
We have a similar history. What seems to be working has been a move to all liquid calories. I had pretty good success with Accelerade in a 1/2 last fall. Recently I went with Sustained Energy plus Enduralytes. No simple sugars. Taste was not the best but I’ll mix with hammergel the next time out to cut the pasty taste. There’s a ton of info on the website and between the SE, Lytes, and Hammergel you can mix according to needs, very versatile. They claim you’ll have less GI upset with their product and it can be mixed at higher concentrations without ill effect. Something to consider given your history. FWIW it did seem very easy on the stomach on an above race pace 4+hr brick.
If you are committed to the g-ade, gu. I would chase the gu with plenty of water. Second when the GI stuff starts, its not going away based on history, you’ll have to slow down and get the GI track back in working order, otherwise you know what’s coming. SLowing down is hard but you know it works based on your training rides/bricks. Better to slow on the bike then the death march on the run!
I’ve got a 1/2 in three weeks where I’ll put the hammergel products to the test. Then its LP for me as well. Hope we get it figured out.
Tip for the Sustained Energy: Sprinkle in a little bit of Crystal Light (non-sugar) lemonade. Tasty and you get a different taste from the Hammergels.
This may sound simple, but why not take a 5 minute stand-down off the bike at mile 75, 80 or 90 and stretch, eat, pee, regroup. Your five minutes of time could save you 45mins or more on the run??? In the grand scale of things, 5 minutes is less than 1% of you overall time.
Just a thought…
Weeman
Thanks Cathy, that should work.
I saw your post on another thread re your IM woes. I thought, might be electrolytes? Any progress on the fix?
I’ll be working on the nutrition thing this summer. One of my informal advisors thinks it might be too many carbos too early. One issue is that I can’t stand almost all drinks or gels (or really, most anything sweet in general). And I’ve tried SE mixed only with water and that was even worse–very milk-like and I hate milk. I’m close to trying water and solid food only, which is what my best century rides have been.
From my own personal experience I have to side with those who recommend you dilute your elctrolyte drinks. During a race I can barely tolerate anything over 50% dilution (1/2 water, 1/2 go juice or whatever you use). I guess the theory goes that you can always pass the water you don’t need (not likely to happen during an IM anyway) but extra carbs tend to stay in your gut and make you sick, especially since most of your metabolism is devoted to keeping you moving forward.
Try Carbo-Pro. It is pure maltodextrin (glucose polymers) and has virtually no taste. I swear by it.
There was a rather heated but informative thread a while back titled Does anyone use Gatorade, or something like that. I have switched my nutrition plan to using only Carbo Pro (maledextrin) on the bike since I have had some of the same problems. I will let you know after Lake Placid if it works.
Yup. I was right in the middle of that one. I just did an 80 mile ride this morning with two large water bottles each with 500cals of Carbo Pro. We hammered and one of my buddies had to beg my emergency Powerbar off me because he was bonking on 3 bottles of Accelerade. I had energy to spare. I think he will be another convert. The beauty of the Carbo Pro is you can get a ton of calories and it tastes like plain water with only a touch of sweetness. I love that stuff. See you in Placid Art.
Thanks for everyone’s suggestions. Slick, what is your routine in using the Carbo Pro? Some of the posts suggest that part of my problem may be ingesting too many carbs, either too quickly or in too high a concentration. Is this a possible problem with Carbo Pro? Also, does Carbo Pro have a website, or does anyone know who carries it in the Tampa Bay area?
Doug
I am going to side with the anti-gel crowd. Same thing that happened to you happened to me at IM-LP. In training, I went with cliff bars, turkey sandwiches and gatorade. Worked very well. Race day, I lost a sandwich and a half on one of the descents. I tried using some gels. BIG time upset stomach right around mile 80, which never resolved. i never puked or anything, but I felt like hell and walked probably 20 miles of the run.
philbert
You could mix 1000cals in one bottle and sip every 20 minutes or so. Pick up a second 1000cal bottle at special needs. If you ride between 5 and 6 hours you won’t be able to absorb any more calories than that. Drink water from aid stations as appropriate for the conditions. Always chase the fuel with some water. I’m thinking of putting all the fuel for the whole ride in a Camelbak Siren (2000cals in 50oz). I’m going to try it out on an upcoming ride.
I used Carbo-pro for the first time on a long ride and it worked like a charm as far as not bonking. However, there was one drawback…it gave me gas which I am scared will lead to G.I. problems during the run of an IM. I’ll try it again because I hate to waste anything.
A couple of things to suggest:
  1. You mentioned stopping during training rides to eat/drink. That’s fine for early season base building rides, but the long rides in the final IM prep should be as non-stop as possible. Same with long runs - try to keep moving for 2 1/2 to 3 hours with minimal stops.
  2. Perhaps your body is trying to tell you something when it keeps fading late in longer races - maybe this is not your specialty. I recall training partners from a few years ago. Strong really fit triathlete. Sub 2:00 for Olympic distance. Kept going back year after years to IMC with big plans, but kept falling apart big time late in the run. He finally cames to the conclusion, that races this long were NOT for him. There IS no shame in this. Many top short course racers have been humbled BIG TIME at IMH and other IM races.
Doug,
I think IM nutrition is the BIG key to doing that distance. I have mine fairly well dialed in after 12 IMs, and it sounds like my goals are similar to yours.
I think you have to go back to the drawing board and think backwards. I.E. How many calories to you need on the bike, then what form. I plan on about 2000 cals on the bike, then I have a game plan to get them in. I practice this nutrition game plan, including timing on every long workout so my body is “trained” to process my game plan. Make sense? Then, The IM bike is just like a long traing ride. And after training rides I have to mow the lawn, take care of kids, etc; so, the IM run, psychologically is a bit of a vacation and I get through it.
Send me your e-mail and be glad to share my “game plan” with you.
I would have thought that initally the answer is to stop and eat as you do in training. If it works in training… Then you work on reducing your stop times until you are doing it all on the move. While initially you will loose a bit of time stopping, it won’t be as bad as walking during the run
