Anyone one of you geeks tried these yet? Coming Aug/Sept '11 but maybe some of you seen them at the trade shows or expo?? I found this info:
"This shoe features a completely level sole with about 3mm of thickness. One of our favorite features in this 5.3 ounce package is the triathlon ready quick lacing system and slip on loops. There may be others, but this could be the first completely zero drop triathlon shoe. And if you didn’t have enough incentive to work on getting your feet off of the ground more efficiently, the sole has bones on it. If it wasn’t enough to blow by some body at the end of the race with your nearly perfect running form, this may be all the incentive you need. This shoe will debut in early fall (Aug/Sept) of 2011 with a red and white color scheme. The spring will feature an orange, blue, lime green (this one looks cool, seriously) and pink. More great shoes in the Inov8 family."
These are the 2012 version. 2011 is due this month and all white with red highlights. Also bare x lite 200 is out too same zero drop shoe with a little bit beefier uppers. Numbers in Inov-8 models indicate actual weights. X lite 150 is 150 grams X lite 200 is 200 grams.
Current X lite 150 model out this month: I was told heel and tongue has pull loops and will come with speed lace option. But the shoe does not have ab actual tongue, its like a slipper with lacing.
