Infinit gel problem fixed
I’ve been experimenting with how best to carry my InfinIT on the run for IMCdA. My solution is carrying an Amphipod bottle and mixing small 8 oz flasks of concentrate. I can get 4 sccops, or 2 hours, in a small flask. I’ll carry them in the back pockets of my jersey on the run. Everything was perfect except the concentrate is so gloopysticky that I couldn’t get the second serving out of the flask. At Gulf Coast I tried adding some water but it still wouldn’t mix up enough to squeeze out of the flask. Today…problem solved. Marbles. Yep. 2 marbles in the flask…squeeze out the first half and mix a bottle in the handheld…add some water to the flask…and let it agitate in the jersey pocket for an hour. Worked perfectly…second bottle was easier to mix than the first.
…just wanted to share that in case it might help anyone else out. Although, this being SlowTwitch, y’all will probably use ceramic bearings rather than marbles :slight_smile:
can you elaborate?
Neal
I am assuming you at least used dimpled marbles :wink:
