I’ve been battling foot issues your about 5 years now, an unfixable condition where a toe basically pops out of place with every step. Had it fused, no luck. Combined with a neuroma that was removed and has come back it’s a constant daily struggle. Combined with having a 4E + foot.
I’ve stayed with Asics 4E shoes forever. Was in the 2060/80 etc until they screwed that shoe up with the new 2000. I’m neutral, but that shoe actually fit my foot so I had to go with it.
After the update I found my way to the Nimbus, the 14 was my favorite and I bought up all I could. Now the 17 is out, with all 15 and 16 being gone, and the update does not work. They’ve narrowed their toe box some and the midfoot is too tight or form fitting.
I’ve been trying whatever I can. Brooks, Nike, Mizuno and the new wide Hoka to name a few. If it comes in a wide I’ve more than likely tried it.
The one shoe that actually seems like it might work is the Altra Torin. I had the original and wore it just as a causal shoe. Didn’t like it for short course racing because I couldn’t get the lacing right. I spend a good bit of time before each race getting my shoes set so the lacing is just the right tension and I can actually force them on. Can’t use bungee laces because of the neuroma.
My concern with the Torin is of course the zero drop. I’ve had my ankle put back together, same foot, a few times as well. In addition to a few knee scopes. So my range of motion in the ankle is pretty low. Which as I understand it could be an issue.
What impact would there be to adding something like a heel wedge? I wear superfeet so I could easily attach a pad to the bottom. Does anybody have any thoughts on if doing this would alleviate some of the issues I might have with the zero drop? Thinking that the lift would create at least a little better angle and allow the ankle to roll forward a bit. Or would the zero drop platform just neutralize any benefit?
I know that there will be a substantial bit of time acclimating to the zero drop. Including working on the strengthening and increasing flexibility in the areas that don’t get stressed by a 10mm +/- drop.
Lengthy post I know.
