I’m currently using a dumb trainer (Kurt Kinetic Road Machine) for my indoor training. Mostly in combination with Zwift. I do a couple of indoor training sessions a week (typically 70-90mins) in addition to longer outdoor rides.
I don’t own a power meter or have any plans to get one in the short term.
To add some variety and because I suspect my pedalling efficiency isn’t the best, I’m considering a set of rollers.
However, there’s a few things I’m unclear on and would appreciate some clarification before making my final decision.
I’m leaning towards a set of Tacx Galaxia T1100 rollers at the moment, but that might change depending on responses!
First off, the Galaxia rollers have two features I believe are intended to make them more stable and easy to ride. That’s the concave rollers (to make it easier to stay central I presume) and the frame fore-aft movement (to eliminate rocking if surging/sprinting I think). These both sound positive, but do they detract from the technique improvement aspect most associate with rollers. In other words, does it make them easier to use and remove the improvement stimulus? Do you favour plain cylinders or curved? Same question for the fore/aft motion?The Galaxia rollers do not have any resistance adjustability. Can someone with a power meter tell me roughly what range of power is available on these? Is it all about cadence, or can you get a bit of load on the pedals too and do a hard steady effort? 300W, 400W, 500W? I imagine I’ll continue to use the trainer for my power focused sessions but I’m unclear whether I could realistically do FTP or VO2 intervals on rollers.I presume there’s no way to usefully combine rollers with Zwift, Traineroad, etc without a power meter?I find the saddle uncomfortable when fixed rigidly in place on the trainer. A common complaint I think. I presume movement on the rollers is sufficient to eliminate this problem and be much more similar to road comfort?Do you think rollers provide a significant benefit when combined with a trainer for indoor training?Any other advice or warnings to share?
Thanks
