I’ve been a long time user of the Withings body fat scale - specifically the latest model, the WS-50.
For those not familiar with this scale, it (and others like it e.g Tanita) use a method called body impedance analysis to determine body composition i.e fat vs lean mass (muscles, bone etc). You stand on it in bare feet, it sends a weak electric current up one leg and down the other and based on the time from A to B, it can determine your percentage body fat.
I’ve always wondered how accurate this is. And in particular, which of the two measurement models it offer - “normal” or “athletic” - was the right one for me.
Withings’ own guidance is as follows: if you work out more than 8 hours a week and have a resting HR of below 60, then you’re athletic. Otherwise, you’re normal. Well, I work out for about 8 hours a week and my resting HR is about 60 so I’m right on the fence.
A little while ago, I came across this: some research into the accuracy of these scales by the revered gadget guru DC Rainmaker.
http://www.dcrainmaker.com/2011/08/bod-pod-consumer-scale-comparison-tests_25.html
His conclusion is that they are on the whole pretty accurate - to within 5% or so.
So I set out yesterday to repeat DC’s tests for myself. Like him, I used the BodPod.
Results as follows:
Withings - athletic mode 8.2%
Withings - normal mode 18.5%
True percentage (BodPod) 14.7%
Pretty disappointing to be honest. Not sure how to interpret this. Maybe it would be more accurate if I was more obviously either “athletic” or “normal”.
By the way, it’s worth stating that from a weight measurement point of view, the Withings was spot on - agreed with the (highly accurate) BodPod scales down to the decimal place - 171.7 pounds.
In the end, I do agree with DC’s conclusion - absolute accuracy is not as important as consistency since the day to day trend is the important thing. So no plans to give up my scale.
But still a little disappointing.
Anybody got any other experiences to report?
