Hi, I recently picked up a '16 Cannondale Slice which is specced with Shimano 105 direct mount brakes. Front brake is no problem as it has traditional adjusters to widen the pad stance. However I cannot figure out how to adjust the rear brake to widen it enough to fit my rear Flo 90. The centering bolt which only moves one brake arm.
it’s not easy to open up that brake enough to fit the flo, and even if you manage to get it to it’s widest point, it barely clears. i had to sand down the pads to get a few mm on either side. i eventually just replaced it with a tririg brake simply because it’s so easy to adjust the width.
Sounds to me like you solved the issue. Why the brake switch were you swapping wheels a lot?
Carbon flo 90 and carbon+al disc. It was a pain switching pads and getting the wheels in and out with minimal clearance. I was never comfortable with the idea of sanding down pads to use on a carbon brake track.
As far as getting them to their widest … I Just messed around with it a ton. Don’t remember what I did
I read that Shimano are introducing a thinner brake pad because their new wheelset is much wider. That may be an option? I don’t know how easy they are to find right now but the wheels are released.
I could but it makes wheel changes problematic. Flo is wider than my trainer wheel.
One would think with all the “genius” advancements in bike tech that brakes that widen and narrow would be a simple matter.
How bout the little lever - you can flip it to widen - does that work? I was thinking you could flip it open for the wide wheel (it’ll still brake fine) and then flip it down for the narrow wheel. Barrel adjuster for fine tuning.
Anyone know how to operate these brakes? Thanks
have you tried, uhhh…loosening the cable?
that only does so much on this brake. it just doesn’t open very wide
Yup, you’re spot on. Cable doesn’t open it much. The in line lever is supposed to be on this bike but mine did not come with it installed for some reason. On the plus side these brakes have excellent performance
Here is a minorly crazy idea that is actually very reasonable.
You should install TWO separate INLINE cable adjusters on your cable. These are the ones where you cut the housing and replace it with an inline adjuster that can go literally anywhere on the cable where you cut.
You will then have 3 separate inline adjusters - two that you’ve cut to the cable housing, and one on the brake junction (the barrel adjuster that’s there already). With 3 of them, you should be able to flip that switch, and then dial all 3 adjusters to open up the rear brake to accomodate the wider tire.
It’s really easy to install the inline cable adjuster - literally just cut the housing, and stick the ends into the rodlike cable adjuster.
it’s not an issue of inline adjusters or not. even with no cable installed, it is difficult to adjust this brake to accommodate the flo carbon clinchers. it has one adjustment screw and it’s not very obvious the best way to “adjust it”
Doh - that’s no good then. Sounds like you need a brake that’ll fit it, or shave down those pads, unfortunately.
