I strongly recommend you get an Ergomo power meter. Here’s why:
- You should get a power meter over a computrainer because:
A) anything you can do on a computrainer can be equaled with the power meter and an indoor trainer. You don’t get the nifty screen to look at, big deal, at least you don’t have to steal the laptop from your wife and kids to ride. You can’t program in the race course and follow it, but guess what, your goal is to keep your power even, so all that you are going to be doing is adjusting your gears to keep your power even as the computrainer sends you up a hill or into wind or whatever…may as well just keep you power even on an indoor trainer. Power meters will log your workout just as well as a CT. You can’t race your virtual self, I guess that is a drawback. No spin-scan, but the usefulness of this feature is often discounted by coaches. Disclaimer…I haven’t actually ridden a computrainer, this is just my logic and impressions. I have looked them over and researched them though.
B) You want to be able to compare what you are doing in your indoor workouts to what you are doing in your outdoor workouts, and what you are doing in a race. You will get a much better idea of what wattage you can hold over various times if you are always measuring it, logging it, and analyzing it. And you definitely want to be able to race with your wattage meter. I am amazed at the number of people who think they must have a disk to replace their 404 rear wheel, that don’t own a power meter…obviously I think a well paced race will be worth a lot more time savings. If you use the same meter for both indoors and out, you don’t have to worry about calibration differences.
- You should get an Ergomo over the other brands because:
A) The only part you have to use that is non-standard is the bottom bracket. You can use any wheels you want, any set of cranks you want (that are compatible), etc. No other trainer is this versital, with the possible exception of Polar, which is reputed to be much less durable and accurate.
B) Best bang for the buck. Price is around $1300.
My second choice would be to get an SRM off Ebay, they go for about the same $1300 used.
By the way, I am thinking about getting an new indoor trainer after letting my old one go for $50 when I moved. Since this one (1up trainer) is built in Platteville WI, 30 miles from where I grew up, I am very tempted to order it. Anyone seen one in action?
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=3668143660&category=7295
