I am trying to improve the tack on my saddle to eliminate any slipping and was wondering if anyone had a solution for that? Is there any aftermarket tape or some trick to make you saddle stickier without damaging bib shorts? I know some pro cyclist use grip tape and just don’t care if they shred their bibs so trying to figure out some alternative.
accept that you slide forward and ride that way or
move saddle back so you ride nose and cant slide forward cuz there is nowhere to slide
adjust position to eliminate sliding
Not what I’m looking for as I have my saddle in a good spot for my nether regions. There has to be some twin stick material 3m type material that has slightly more friction.
My recommendation would be to give the following Stickum Spray a try. I looked for some in Cozumel because it was so humid I found that I couldn’t really hold on to the aerobars and wanted to use it to enhance grip on bar tape. I have no idea what it will do to clothes
I recently got a pair of Compressport tri shorts that seem to have a sticky surface on the outside of the pad. I haven’t ridden with it yet, but it sounds like what you’d be looking for - something to increase grip between saddle and shorts.
Interesting. So no experience with the residue or use whatsoever? I’ll look into it.
Not sure what the residue would be like on clothes but this is what wide-receivers in the NFL and NCAA use to catch passes. Effectively cheating IMO. If you do use it on the saddle, I would be interested in hearing feedback down the line for that purpose.
Saw this on another forum- another interesting thing to test
"cut up two small sections of inner tube and slide it over the prongs, use a hair dryer if needed. If you want to go nuts then get some sandpaper and roughen the inner tube as well. I think this might have been enough to solve the problem but I went further and super glued bits of inner tube strategically all over the saddle.
I’m now rock solid on the saddle, in fact to change position I’ve now got to ‘unlock’ myself off the rubber(butyl) then move."
They(3m?) make a rubberised electrical tape. Usually called splicing tape. It’s electrical tape, but it’s thick, and rubbery… maybe a few wraps of that around the saddle nose would help. The rubbery aspect being the value… you can get it at any hardware store.
Good luck!
