How to get my saddle higher - Plasma Pro question
Apparently, I should be riding 1 cm higher on my Plasma Pro. I already got the seat post extender, still too low. Any ideas? I was thinking of bending my seat rails.
use longer crancks
Get a harder saddle?
Lower profile pedals/cleats?
Gotta see pix of the seatpost showing!
i feel for you.
you may be s.o.l.
and this is a major major flaw of intergrated seatmast bikes.
use longer crancks
actually if he used shorter cranks, he could
keep his seat where it is.
find a seat with a higher stack height, or shorter cranks.
either way you may want to go up a size in frame rather than be at the extreme limits of seat height.
use longer crancks
Ummm…no. Using a longer crank effectively increases the distance from the pedal to the saddle at BDC.
Why/according to whom?
Some suggestions here are good already. (BTW, you would want LONGER cranks not shorter).
Here’s another suggestion: move your seat backward a little? Not necessarily conducive to a good TT position, but would increase the distance from seat to pedal.
Seats from Fizik usually are taller than other seats.
eh. my bad. let me rephrase that.
shorter cranks, move seat higher.
longer cranks, move seat lower.
he says he needs to be higher(why?)
so yes, longer cranks would drop him down a bit,
but re-reading this, i’m inclined to agree that he may
actually need a larger frame, rather than mess with
the seat post and/or cranks.
My fitter recommended getting higher (my seat). Ass did my coach. The front of my knees gets sore. I’ll maybe look into the longer crank option, I’d like to switch to outboard bearings anyways.
My seat is the stock Fizik, I don’t know of any tri saddle with higher stack?
The fact that you get pain at the front of your knee is indeed consistent with your saddle being too low. That isn’t the only possible cause, however, and even if it is, I don’t think longer cranks (which will require that you bend your knee more at the top of the pedal stroke) are the solution.
