My BB is over 3 years old with ~20K miles on it. How often do y’all replace them. Right now I have a SRAM GXP on my bike. Any suggestions for a non ceramic upgrade? Hawk? Chris King?
Mine has the pf30 bracket. I replaced the bearings at 38k miles, as they started to make all kinds of funny noises and scratching sounds. I have 22k on the new bearings and all is fine. I did have it cleaned and serviced a week ago. Bearings are fine though. I would say to expect 30-40k miles from the bearings.
My bike is similar in age, I took the chain off and noticed some serious rubbing sound when I spun the cranks. BB was bad. I went with Kogel.
Really when it’s necessary. Hard to give an exact mileage since riding conditions vary so much. On my CX bike I replace on average 1.5 times per year. Road/Tri much less often.
I have a Cervelo 2008 P2c with a MegaExo BB that came stock with the bike. I did zero maintenance to the BB since I’ve owned it and rode it pretty hard.
That BB was perhaps the one piece on my bike that was NOT fused solid from sweat/age. It was actually greased well, came out easily, and had plenty of goopy grease still in there. Pedaling was also totally fine, no catches, no problems.
I suspect if a BB is installed correctly, it can last there for a lonnngg time on a road bike.
I have GXP to fit my Quarq. To answer your question…
When I was using SRAM stuff, which I now assume to be made out of carrot cake? Frequently.
Since changing to Hope? Never. Steel bearings.
**Really when it’s necessary. Hard to give an exact mileage since riding conditions vary so much. On my CX bike I replace on average 1.5 times per year. Road/Tri much less often. **
This!
There is no one answer here other than - when it needs to be replaced!
The variables are riding conditions (wet/dry), volume of riding, style of BB etc . . .
If you take the chain off the chain-rings and then let the crank spin freely - what does it feel like? When the BB and bearings are in good shape (and installed properly), it should spin freely easily and with no noises. If it’s not spinning freely, or there is any kind of noise coming from the BB, then it should be looked at and replaced.
x2. I had to replace my SRAM GXP BB around every 6 months… I’ve got over 2 years on a Wheels Manufacturing GXP BB.
About every 100,000km (it’s an SKF square taper).
Wonderful things.
