As mentioned, there is and was a significant current in the course, as well as it being short. But it was the paces within the swim that show.
Outgoing tide from a harbour, mainly left to ride water movement.
First 275m were up the beach into the general current. However water really shallow if you were on the beach side not swimable so lots of people stopping and walking. If on right side of course then could swim, but equally as so shallow then the speed of current very mnimal. That said, those at front of waves would have a current that they expereinced, but as normal, those in teh ‘pack’ behind shielded. As it was the short first leg then this meant mid swimmers stayed on feet of the stronger to the first turn.
At this point it was a 160 degree turn and then the big long leg with full current assist. I averaged 1:15/100m for this. In this case the current minimises the speed differences between swimmers and I got lucky to have a single swimmer to draft off that was taking the correct line. Most seemed to go slightly left (even to teh point of going wrong side of the first mid point bouy). This added to their swim distance, but also minimised the current assist they got. Again, on that course you want to be heading towards the monument for the max current.
Then there was a real trick to the course at the second turn (short leg to shore). That had the huge head and cross current. But more the third bouy was hidden behind a boat so you needed to do a dog leg. The smaller the god leg the shorter you went and critically as this was where the water was working against you most, then you could lose a lot of time here. And I think that’s what happened to quite a few people. There was a lifesaver on a board guiding people to the right of the boat blocking the bouy, but then I think a lot of people fought the current too much and went too far right, then needed to backtrack further.
Last leg along the beach, essentially if you went along the beach you swim a big banana - follow the bouys and it’s straight. In this case the eddy current you get means you don’t fully pay for the assist once you get away from the boat ramp.
Final thing, that shallow finish also gave lots of chance to gain/lose time/places. If you swam as far as you could then you could save a little time over those that stood and walked in the waist deep. But where it got most significant is if once you stopped swimming when it was too shallow to get a full pull, and then skipped/ran out the water you hit the timing mat long before those wading through the water.
Last time I did Tga then Taupo full I did 31min flat here and 1h07m in Taupo.
For context, I always have a significantly better ‘placing’ in this swim than Taupo. And in squad swims I’m with similar people (apart from one) pool to OW where we all know the currents.
From Saturday my 500m split averages were 1:35/100m, 1:14, 1:48 and 1:54 (for last 375m).
