How much difference do shorter cranks make for IM bike and/or run?
I’m getting back into tris after spending 4 years racing crits/rr/tts. My current bike is a gen 2 Speed Concept with 170mm cranks, which has served me well (I’m 5’11") I feel very comfortable on it and can hold aero position for multiple hours. My previous stent into tris included sprints and olympic distance, but next year I’ll be doing IM Florida. The bike will undoubtedly be my strongest discipline (plan on between 4:40-4:55). It seems that because of the BB90 bottom bracket, the shortest cranks I would be able to fit on the SC would be Shimano/SRAM 165s.
Question 1: Would switching to a shorter crank benefit me either during the bike or help with my run?
Question 2: If so, would switching to 165 make a meaningful difference, or do I need to switch to something smaller?
Question 3: If I need something smaller than 165, does anyone know of one that will fit a SC with BB90?
Question 4: If there isn’t anything smaller than 165 that will fit the SC, would going smaller be worth selling the SC to get a different bike?
Thanks in advance for the help.
  1. Potentially both
  2. Possibly. It depends on your current fit.
  3. Look at rotor. You will need a crank that is 24mm to fit the shimano bb90 bb.
  4. Doubtful
Unless you enjoy testing things on your own, I would suggest finding a reputable fitter that has a dynamic fit bike where he/she can easily adjust crank length so you can see how it feels and how it opens up your hip angle. It also can allow you to get in a more aero position. You can then decide what crank length you like. Remember that once you go shorter cranks, your seat needs to be raised, pushed rearward slightly, pad y needs to be raised, and pad x needs to decrease to match your current fit.
I’m about your size (5’10") and I have had a couple SC’s. I’m running 165mm cranks. I was running 172.5mm cranks years ago but have found the 165mm cranks enabled me to be in a much more comfortable and aerodynamic position. I also have hip impingement issues so the 165 cranks have helped with that too.
What crank are you currently running? If your current crank has a 24mm spindle then the sky is the limit. If not then you can get an adapter. Same goes if it’s GRX or DUB. Check out Wheels MFG, they’re pretty good about having parts to make parts fit.
I’m 6’1 and went with 160 arms on my TT bike and 170 on my roadie. Just pay attention to the finer adjustments to what Steve said about adjustments to this and that.
As to fit, my hip flexors have never felt better while in position.
Thanks, guys. Unfortunately based on my research, Rotor won’t work (spindle isn’t long enough) and DUB won’t fit either.
Rotor 155mm cranks.
Belay my last…Rotor will work!
Not that height is the best proxy, but assuming ballpark 730-760mm saddle height, the most common self selected crank length at your size is 160mm. The difference between 170 and 165 is significant. Rotor basically fits in any bike and goes down to 150mm. The crank is integral to approaching your most aerodynamic posture while maintaining aeorbic power.
I’m a big believer in my 165’s at 5’10”.
Sure, aero is slightly more comfortable, but the big advantage is in less strain on brick days and racing.
The combo of slight impingement at the top of the pedal stroke that would create a little hip rocking and then hammering up the legs running would create a lot of discomfort in my hips and lower back.
I converted one bike and eliminated the pain, but then occasionally rode another bike and would wake the next day in pain. Over the next year every bike got 165’s and a similar bike and I am pain free.
My fitter told me to take my 165mm cranks off my Tri bike, put them on my road bike, and buy a 155mm Rotor crank for the Tri. The idea being that the shorter crank (172.5 to 165 on road and 165 to 155 on Tri) was to open the hood up more and spin faster. I was skeptical but damn if he wasn’t right. Feels smoother with the higher cadence and I feel like I can sit in aero position more comfortably. I am 5’10” with a 29.5” inseam … short legs.
I’m a guy who doesn’t have access to test things and do things by feel and stuff. I used to have 175mm crank and switched to 165mm. Everything remained the same. All I can tell you is I PRed in bike leg in 70.3 race recently and still had the decent run so I would say go for it. I used 175mm crank because the it came with the used bike. I rode like that for several years and decided to try 165mm because ST said so. I’m a guy who leaves things alone if they are not broken but shorter crank was one thing I had to try because my knee came up pretty high. I’m 5’8 and ride size 51 frame.
You should try 155mm cranks.
I would like to but I don’t want to spend more money on my bike. Enough is enough I guess.
https://www.youtube.com/...b_channel=PeakTorque
There are a million videos on what is right and wrong about long or short cranks by every level of YouTube expert.
Came across this one and couldn’t resist muddying the waters…👼
It’s about time to change my chainrings and I am currently riding a 165mm 50/34 compact SRAM Force 22 GXP. With a 30" inseam I have seriously been considering 160mm crank arms and would not be opposed to trying 155mm in order to raise my seat a bit. This would open my hip angle on the up stroke which I think would be an improvement. Apologies to the OP but I have a couple of questions as well.
  1. 10mm or 5mm reduction in crank arm length would be a pretty big change. Would I need to go to standard gearing (53/39) on the new crankset?
  2. Neither 155mm or 160mm crank arm length cranksets are easy to find with 24mm spindle required for bb90 bottom bracket. Where can I find one?
It’s about time to change my chainrings and I am currently riding a 165mm 50/34 compact SRAM Force 22 GPX. With a 30" inseam I have seriously been considering 160mm crank arms and would not be opposed to trying 155mm in order to raise my seat a bit. This would open my hip angle on the up stroke which I think would be an improvement. Apologies to the OP but I have a couple of questions as well.
I am no expert, but for me I had to raise my seat (started at 8mm and ended up about 11mm with the fitter) when I shortened my crank because the bottom of your pedal stroke is not as far. This also caused me to move the seat some. Basically, when you shorten your crank you will need to take a look at your seat height and front/back position. Lastly, the length of your crank is independent of your gearing. I did find that I spin much faster with the 155mm…. About 90-95 rpm.
As for finding a short crank, did you look at the Rotor 3D modular system?
You could shorten your cranks by 20mm and be fine.
Rotor Aldhu 24.
I did look at rotor. I could only find 165mm with a 24mm axle to accomodate the bb90 bottom bracket
I assume you moved your seat back a little with the 10mm change to crankarm??
Rotor Aldhu 24.
Ahhh… was looking at VEGAST… Thank you
Rotor is compatable with Trek SC? No adapters or spacers?
Just get the standard 24mm axle.
Crank length is part of the gearing between foot and wheel. A shorter crank means that in order to maintain the same foot speed you will run a slightly higher cadence (as you noticed), so for the same bike speed you would need to be in a slightly lower gear. I agree it is unlikely that in practice you will notice this through a required change in gearing (though you may end up being one sprocket further up in the cassette). You certainly don’t want to get bigger chainrings though - that would be the opposite of what is required!
