Before tri I rowed, lifted, this & that, even one regimen for a while that consisted of all body weights (pull-ups, push-ups, and sit-ups plus swimming and short runs).
I bet I can do more than Thibault Pinot . . . Will give it a go in the morning. Haven’t done a push-up for maybe 6 months . . . I’m gunning for 36.
Push-ups for rowing? Huh? While rowing, I think I did all of about 10 push-ups. That being said I could do 90 bench pulls in 2 minutes with 90lbs of weight and 47 pull-ups at the time. Now I’m lucky if I get over 10 pull-ups.
99% of people who will post their scores are posting BS numbers, a push up should be chest to deck with a full lockout, i would bet there are fewer than a handful of people on here who could go over 50 in one set (no resting in the active rest position). Over 30 is in fact fairly decent with proper form when compared to the general population, i think 50 would be a good indicator of a fit individual, and above 70 is getting into the more impressive numbers. Same with pull ups, lots of people will say easy around 20 but 99% are not doing an actual pullup.
I can get 102-105 in one set, around 130 in a 2 minute set with active rest, pullups 31-35 depending on the day, that was good enough to top out my BUD/S class. Now if you consider one set as long as you can stay in the pushup position i have once gone well over 200 pushups but that was a forced situation that i have no interest in ever replicating.
I actually do 150 every day, 3 sets of 50. Usually do one set before I leave for work, one set when I get to work (file room), and another set before lunch( file room). And if I’m feeling froggy, I may get an extra set sometime in the afternoon.
I have 3 other friends that keep a text thread open and respond when we have completed your 150. So when you aren’t feeling up to it and the 150 texts start rolling in, you feel accountable to get off your ass and get yours.
I would like to see 130 in two minutes. All the people I have seen who can do 100+ in two minutes don’t do proper push ups. Their body doesnt move up and down as a complete unit. They kind of have the ability to make their hip like a hinge and from the waist down it doesnt move or barely moves, but from the waist up their arms are able to get in a 90 degree or less angle at the bottom of the movement. chest low, and the lock out at the top so it looks like a good push up from the waist up. The most I have seen done in 2 minutes using authorized military rest positions was 96. Given your BUD/S background I am not doubting you, just something I would like to see. With that said, if you have any routines that you would be able to suggest to get to 77 in 2 minutes (Army PT max) send it my way, I have only did that once usually end up with in the 50s maybe low 60s for my recent tests. No problem hitting run and sit up numbers but triathlon training doesnt help my PT test push ups. I want to incorporate a calisthenics only strength routine into my training so again, any recommendations please send them my way
Yep, I agree. I do 40 push ups but do not lock. I do 4-6 pull ups doing this correctly. Am a wuss.
The most I’ve ever done in one set is 96. (And no -Mike-, that’s no BS.) It was with a monitor who made sure I used proper from (I had two disallowed). It did take me a lot longer than two minutes.
Admittedly, that was back in my early 20’s. I’m 61 now and still do three sets of 25 every day before my morning shower. All fingertip pushups by the way, that’s how we had to do them in wrestling practice going back to the eight grade. Still like doing them that way.
at the naval academy there were quite a few dudes hitting 101 in 2 minutes as that was the max. they started to acknowledge doing more i think my sophomore year so most of those guys did a bit more. we did them chest to someone’s fist and they would count for us. to mike who went through buds i would guess that if we all had to hit the floor (another 2-3 inches) if would take a good 15-30 off of everyones max. having built up that base of doing pushups for 4 years i was tested in a ex phys class after having done none in over 2 years i was still at 90. today… maybe 70 but my bench max went up so im sure i could still get to my all time max after some time. all time high 147, but again that was hitting someone’s fist. chest to deck should probably be the real way to count.
About 80. I did 100 once about a year ago. I think I have good form, touching or almost touching the floor with hips and nose on most reps, not quite locking out at the top (98% extension? - I don’t like the feeling of “locking out”). I often do several sets of 50-70.
I can do 20-25 chin-ups (maybe 18-20 pull-ups)
I started doing bodyweight exercises about 2 years ago, as its easier than making it to the gym.
Retired military (Navy) in 2002. At the time I could max out all 3 events in the PRT for the youngest age group. I can probably still get close on the run. The pushups and setups would be a challenge.
I may need to go to Groton this month and participate in a selectee PRT just to see what happens. I’ll bet I could still make the majority of the slugs looks silly.
