if you ride a tri bike in a way similar to the positions you admire when you see images of pro athletes, your weight is never going to be less than 50 percent on the front wheel. a good front wheel weight is maybe 55 percent when you’re in the aero position.
the way you keep your weight at about 55 percent, or at least less than 60 percent, is by having your pads sit not too far in front of your steering axis. your pads are where you weight the bike (in the front) and if your weight sits too far in front of the steering axis your bike will not handle optimally.
if your stem is 90mm long, fine. if your stem is 140mm long, but you’ve pulled the pads back 50mm (by for example sliding the extensions back in their clamps, assuming the pads are clamped to the extensions) fine. it amounts to the same thing, tho in this case the difference is now in where the pursuit position is, even though the two examples are functionally the same in terms of weight displacement.
dave (findinfreestyle) is a good athlete, he’s a good coach, he’s a really good swim coach, and he seems to be in the “you can get used to anything” camp. if so, he’s right. you can get used to anything. but you can also get used to drinking boone’s farm, thunderbird, and 2 buck chuck. because you can get used to it, is that the same as requring you to settle for it?
one thing i noticed when watching the really good time trialists in richmond this past week versus the guys finishing 2min, 4min, 5min down, is how nice a line that front wheel tracked for the best riders, versus some time trialists who looked like they were doing the paperboy even while riding on the flats. if you want your bike to be a nice, easily, elegant handler you will not have your weight much in front of the steering column. this usually means a stem 25mm or 30mm shorter than you’d use on your road bike.
still, dave’s right. you can ride a long stem on a tri bike. just, as you get more and more into thorny situations, you risk more and more that the bike will not perform as you want. what is a thorny situation? winds when you’re trying to ride a 60mm or even deeper front wheel. descents. descents in windy situations. descents, braking, corning, deep wheels, all at the same time.
