How do you convert a road bike to a single speed?
I know you need a different crank, lose the derailleurs, new rear wheel with prope hub. What about the spacing on the rear? I know road bike are 130 mm. How do you accomodate for this? Anything else I’m missing?
Thanks
Start here: http://sheldonbrown.com/singlespeed.html
-Dave
If you decide to use a track spaced hub and crank, you will need a track spaced BB to get the chain line right. If your dropouts don’t have enough horizontal play (most modern bikes don’t), you will also need a chain tensioner, but this will limit you to riding SS.
Of course there are a myriad of ways to convert a standard double into a SS, as outlined on Sheldon Brown’s page
Second Shelldon Brown’s page. I took my old Ironhorse road bike and converted it over to single speed. I bought a forte conversion kit for my rear hub. It included a chain tensioner and three different rear cogs. I primed and painted the old frame with spraypaint from the auto store and then put the bike back together. I also bought a new set of brake levers and a cool leather looking saddle. It came out looking really cool and is fun to ride. I use it to commute get groceries and get to the local watering hole.
Don’t shift. Done.
No, I’m serious.
I’ve done this w my old hardtail mtb - put it in a SS-esque gear (2/1 ratio is pretty common) and then just never shift.
Had one of these put on in conjunction with a flip/flop rear wheel. A few years & umpteen thousand miles later, no problems. And I’m pretty sure the single-speed/commuter bike is my favorite in the stable.
no need for a new crank, just a different chain ring, especially if your current crank is a compact, but you should still be ok with a standard.
a couple of cogs in the gear range you are looking for.
surly hub converter set
chain tensioner
brake only levers to replace the “brifters”
Shoot me a pm if you are interested in some parts, I have a single speed I might be breaking down.
I converted my old road bike. Got a spacer kit for the hub plus and a Shimano chain tensioner and Alfine crank. Still use 9-speed chains on it. Probably didn’t need to buy the crank but I wanted to use the old compact I’d had on there elsewhere.
I converted my roadie into a singlespeed with a White Industries ENO rear hub. It’s now my favorite bike by far, so you have been warned!
Took my old road bike and…
  1. Took off the derailers.
  2. Took off the big chainring (had a triple) and smaller if you want- I just left the smaller. Put the chain on the 39.
  3. made my own cassette using a bunch of old spacers and 3 cogs- the 17 for the chain and two bigger ones (like a 23 or something similar) right next to the 17 on each side so the chain doesn’t fall off.
Presto! cost $0.
I think I saw a hipster with this set up one time and I just decided to try it. It might be my favorite bike to ride now.
Pictures if you are really interested.
I have used the whote indistries hub with a bike with vertical dropouts as both fixed and ss for three winters, its expensive but well built. I run a 39 x 16 for training in rolling terrain
Zip tie your shifters…done and done
Best answer!
OP did say single speed and not fixed gear. Just don’t shift and you get that single speed experience. I’ve got a single speed and a fixed gear. Completely different riding sensations.
  1. Buy some skinny leg jeans.
  2. Get a stupid haircut.
  3. Hang out at coffee shops.
  4. Blow through stop signs and traffic signals.
  5. Get your eyebrow, nose, lip pierced.
Ha!
