How do I raise (angle) 3T bars
I want to experiment with angling my aero bars up a bit. I don’t see a way to do that with the 3T bars that came with my P3. I see I can add spacers to go up flat, or I can rotate the base bar in the stem. But rotating the base bar seems like a bad move aerodynamically.
You need angled spacers. Aerocoach among others has them.
Thanks for the shout :slight_smile: we do a tilt block adapter which moves both the extensions and arm rests upwards and have 3T compatible kits, the angled spacers will work to do the arm rest only, but best on a flat surface (not some 3T Aura where the clamp area for the arm rest is tiny and falls outwards at an angle)
Thank you for your response.
I see the pad angle spacers on your website, but nothing like a “tilt block adaptor” which sounds like what I need. Do you have a link?
Sure thing, it’s on page two of our webshop (which needs updating!):
https://www.aero-coach.co.uk/store/product/aerocoach-tilt-block-adapter-for-aerobars
